Adding 2FA to SSH
Is the community aware that SSH supports 2FA?
What are your thoughts on enabling this by default (ie tie it to the same 2FA seed for umbrel web login or not)?
Pros and cons?
Has occasion to enable 2FA for the GUI but it was not handy now at the beginning as I needed to access umbrel.local really often to setup and initial maintenance.
I’ll probably enable it again when the node is running properly
I kind of expected 2FA to be on for SSH when I enabled it on the web. Would be nice :slight_smile:
I’m not sure why you want to enable 2fa on the web, when you can still use the same login and password in SSH without 2fa :slight_smile:
