Accessing Umbrel from a domain
OK, guys, I need a little help - I got my umbrella home in the mail today, all setup and running. Having an issue.
I use Tailscale, id like to be able to access Umbrella from my domain.com, the reason being I used NGINX proxy manage to issue SSL certs using Tailscale is the only way I can see to get an IP as you access Umbrel through umbrel.localk
When I point the domain, to the timescale IP it does propagate it goes to the domain.com I want to use, the issue is adding the SSL
Nginx proxy manager is throwing an error that the IP is not pointed to my NPm instance, how can make this all work, I am so lost right now and I cant get the cloud flare tunnel to work right
Anyone that can help much appreciatred
