A few concerns with no backup support
Hi
I recently started using Umbrel, and I understand that this is primarily designed for individuals new to setting up Homelabs. As a technical person working in the tech industry, I believe that this out-of-the-box solution lacks certain features that should be included in a 1.0 release.
Firstly, there’s no built-in backup method or way to mount an external NAS. The terminal warns that any changes made may be overwritten after an update. Additionally, if you install Duplicati from the App Store, there’s currently no way for Duplicati to access data from other applications like NextCloud or Syncthing to perform backups.
I couldn’t find any documentation for UmbrelOS that explains how these features are supposed to be implemented if they are supported.
Lastly, in regards to documentation, I can’t seem to locate if any Telemetry data is being sent back to Umbrel HQ.
