Now that we know https://hackaday.com/2022/02/04/a-64-bit-raspberry-pi-os-at-last/ raspberry pi released a 64bit OS. Does the umbrel server also run off a 64bit architecture? I ask this as a new user, just got up and running this weekend with my pi4 8gb and argon m.2 case.
Humm… Yes it´s 64 bits. Try a little more reading, dear.
You can see if the OS is running on 64-bit if you SSH in, it’ll be on the first line. For example, my node gives me this
Linux umbrel 5.15.18-v8+ #1520 SMP PREEMPT Fri Feb 4 12:04:45 GMT 2022 aarch64
The aarch64 indicates that it’s running a 64-bit OS.
Thank you. This was helpful, I learnt how to check for it.
