I just had enough space to upgrade to Umbrel 1.5
Then upgrade a dozen app including Core v30
My advice should be to delete non core applications (IE ride the lightning, thunderhub or the ones you might have).
Prune or change the disk and reinstall later.
Time for a new SSD
I had the same problem. I managed to temporary fix it by reducing the ext4 % of reserved space for root from 5% (default) to 2%.
