Jam wallet loads for a second after loggin in but then this error page appears. I have updated umbrel and reconnected/disconnected from tor and wifi. How can I resolve?
Have you solved your issue?
yes I just checked this morning and the issue persists. any ideas on how to solve or why this is happening?
Yes
Let me know once you are ready?
im ready. can you please post your feedback on the issue here? for others to see in case they run into the same problem
I had the same issue yesterday and a simple restart didn’t work. Today I got it working by shutting down (powering off not just restarting) my node, letting it sit for a minute and then powering it back on.
thanks! that seemed to work. i shut it down for 5-10 min
