@btc_ln igniter only works if there’s a route back to your node through another channel. mostly it’s not the case.
@Deekee Consider providing balanced channels a service. So maybe you should insist that the counterpart is the one to open a channel, push 1/2 amout through and you pay them back on-chain.
Oh, yeah, igniter is good for triangles and squares. Upon the channel opens participants meant to set their fees high, so nobody rebalances through them. Then, at a certain time every participant sets the fees to the lowest or the same and then do the igniter thing in a circle. We did this on twitter with 3 other participants and we got nicely balanced channels at no cost or risk.
Glad you got your sweet sats back, Deekee. Still countin’ with ya , I am sad that Umbrel does not work for me, but I am syncing MyNode and once ready, I will be happy to open that promised channel with you
