Opening Channels Requests
Ok, so you have your Umbrel node ready, is time for you to connect it with other peers, in order to be able to transact (send and receive sats over the LN).
First things first, a simple checklist for noobs:
  • Is your node 100% synced?
  • If no, wait for it, is better
  • If yes, send some good amount of sats to your node onchain wallet, I will say at least 2-3M sats
  • Wait for the tx to be confirmed (at least 6 confirmations)
We can post here our proposals for opening channels between each others. But let’s have some basic rules:
  • minimal channel size to be 500k - 1M sats, for a better routing and minimal fees
  • channels size between 100k and 500k should be only for special cases or services, that doesn’t need high volume (eg. Sphinx chat, podcasts, tipping etc)
  • DO NOT close your channels, just because you don’t use them or you don’t like them. You can loop out part of the funds if you need them for other purpose, but is not really necessary or indicated to close the channels. Those channels can be filled anytime again, with lower fees, or just used to receive funds through LN
  • KEEP ON 24/7/365 your node. A node that is quite often shut down is useless to everybody. So be prepared to keep it alive as much is possible
  • try to create your own rings of nodes, will be much easier for you to communicate with other peers. Once you have a small ring, you can connect with other big rings or big nodes for a better routing
  • ask here politely if somebody is willing to open a node towards your node or if you have available funds to open channels towards their nodes
  • opening a channel towards another node is OUTBOUND liquidity for your node (the amount you can send)
  • opening a channel towards your node is INBOUND liquidity for your node (the amount you can receive)
  • Rebalancing: opening a node towards another node, will not have automatically inbound liquidity (you can’t receive sats to your node). How can you fix this? Simple. After you open a channel and is confirmed, you have 3 options:
    a. Loop out (to your onchain wallet) half or less of the amount you used to open the channel. Those sats later can be used to open another channel
    b. Send out through LN to another LN wallet of yours, or buy stuff, or send to a family member. Later you can receive it back when you need more outbound liquidity.
    c.Using rebalancing tools from the apps RTL or Thunderhub, to take a sats amount from a channel that have too much outbound liquidity and move it to another channel that have too much inbound liquidity. Practically is making a payment to yourself.
There is also and additional way, to connect with more node operators. Some other users, passionate with nodes and LN, they start organizing the so called “Rings of Fire”. Basically creating groups of specific size channels, inter-connected, offering fast and reliable routing, helping each others.
You can find more information about how this works here.
They also have a dedicated Telegram group, where the rings are organized.
LN Balanced Channels - another Telegram group for opening channels and help others with liquidity. Here is the link to their group.
Awesome! Excited for others to open channels to my Umbrel node!
CODL STORAGE SOLUTIONS
028958fc522dc6bb0de747b6e3eacdcae0ad5de2cbd23143f0a8a3fa9c4675dfb9
Would love more channels towards my node, I really want to see LN grow a lot bigger. More channels and more corn!
036a2f674fc446a42044f6c58bd85dcedd2f027fc42300f001b9ec24431cc8e824
I’m still figuring it all out but mi node es su node!
039104f8194c6f181eb54086f04321a3a4534f918d1196fa9684ee4a6bf1358a4d
Great help already
I was looking for exactly this info! Thanks!
Question: when I restart my Node for whatever reason does the channel have to be reopened or does it persist?
Thanks! I will do. It’s exactly what I was looking for.
Find my node here: Node Up or Shut Up
1mm sat minimum, please.
looking forward to you opening a channel to my node
034a1eb289a1fdc41f39b1683899af9c9abbedde2aa46af5814183f5e27329bc42
Nice name, nice limit
Channel will persist.
If anyone got a routing node with an average channel size that is more than 1M sats, and want to connect to a large node with a 5M sats channel (minimum) hit me up here or | Twitter: Seccour_Fr | Mastodon: @Seccour@bitcoinhackers.org
My node is a well connected, always up, routing node with a lot of liquidity (top 100 on 1ML)
feel free to open channels. high uptime and decent liquidity
02680d3b6f0a8a1bc342332a3034f8bfd4b07d8d39dc4b04f99780b9d560978484@zmlphygzxpnsysy6m4bgmymx2lc7twdhaoticxsoi4wa5toliylgmoid.onion:9735
0270fb39effcfc32995797891f6fbc1891d6425b9ed78417ca4d8638e13ac23c7c@f6pmapdzgbpmdnjwvagy3gi2wshrfbpa3njvz27u665ftih67mm5t3id.onion:9735
I can hit back with 500k.
I’m still learning here, totally understand if I’m not moving enough sats around as a router.
Anyone want to open a channel towards my node? Looking for some inbound liquidity. I promise to be a super responsible node operator :sunglasses:.
03d2e20bc19d995098ba357157a9cfbfbfdff4b78fce5ec713128e988e0115d776@2cbjcqmi4fidgbhwqlivbgj4qx4de2ytbqgppynz63kbsf42qy6phjqd.onion:9735
0275d0eeffb915a8b9ecb26c3d5992756b4c0e870b147a820c18b8a1a4572ef9a6@7ipsr6ywfi45l6awuigjpyseafd4z4fqwrojixd5t4jdprll42cg4oad.onion:9735
Please open to me I’ll be on 247
Opened please open back :wink:
Thanks! on it. To all else - I’m tapped out for now :slight_smile:
Would love to open channel and help spread the LN community.
MasterYoda
https://1ml.com/node/033dee9c6a0afc40ffd8f27d68ef260f3e5e1c19e59c6f9bb607fb04c1d497a809
