Getting message below, presumably after power outage. Already restarted/rebooted and shutdown my Raspberry pi 8gb. Also flashed my mSD with latest UmbrelOS but no luck yet. I am able to login using SSH but running commands like
docker ps
or
Result in the error “Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?”.
Also command
systemctl status docker
results in
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2022-06-11 13:21:31 UTC; 32min ago
Docs: https://docs.docker.com
Process: 16355 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=2)
Main PID: 16355 (code=exited, status=2)
docker.service: Service RestartSec=2s expired, scheduling restart.
docker.service: Scheduled restart job, restart counter is at 3.
Jun 11 13:21:31 umbrel systemd[1]: Stopped Docker Application Container Engine.
Jun 11 13:21:31 umbrel systemd[1]: docker.service: Start request repeated too quickly.
Jun 11 13:21:31 umbrel systemd[1]: docker.service: Failed with result ‘exit-code’.
Jun 11 13:21:31 umbrel systemd[1]: Failed to start Docker Application Container Engine.
Debug info:
0.4.18
Flashed OS version
v0.5.0
Raspberry Pi Model
Revision : d03115
Serial : 1000000010da26c1
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=44.3’C
Throttling
throttled=0x0
Mem: 7.8G 117M 7.3G 8.0M 378M 7.6G
Swap: 4.1G 0B 4.1G
total: 1.5%
system: 1.5%
tor: 0%
mempool: 0%
lnd: 0%
home-assistant: 0%
electrs: 0%
btc-rpc-explorer: 0%
bitcoin: 0%
Memory monitor logs
2022-06-11 13:19:35 Memory monitor running!
2022-06-11 13:19:47 Memory monitor running!
2022-06-11 13:19:59 Memory monitor running!
2022-06-11 13:20:11 Memory monitor running!
2022-06-11 13:20:24 Memory monitor running!
2022-06-11 13:20:36 Memory monitor running!
2022-06-11 13:20:48 Memory monitor running!
2022-06-11 13:21:00 Memory monitor running!
2022-06-11 13:21:12 Memory monitor running!
2022-06-11 13:21:24 Memory monitor running!
/dev/root 59G 3.1G 53G 6% /
/dev/sda1 916G 527G 343G 61% /home/umbrel/umbrel
Startup service logs
Jun 11 13:21:25 umbrel umbrel startup[16068]: The NGINX_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The BITCOIN_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The LND_REST_PORT variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The LND_GRPC_PORT variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The LND_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The MIDDLEWARE_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The MANAGER_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The NEUTRINO_SWITCHER_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The ELECTRUM_PORT variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The ELECTRUM_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:25 umbrel umbrel startup[16068]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Jun 11 13:21:26 umbrel umbrel startup[16068]: The Compose file ‘./docker-compose.yml’ is invalid because:
Jun 11 13:21:26 umbrel umbrel startup[16068]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Jun 11 13:21:26 umbrel umbrel startup[16068]: services.tor_proxy.ports contains an invalid type, it should be a number, or an object
Jun 11 13:21:26 umbrel umbrel startup[16068]: services.bitcoin.ports contains an invalid type, it should be a number, or an object
Jun 11 13:21:26 umbrel umbrel startup[16068]: services.electrs.ports contains an invalid type, it should be a number, or an object
Jun 11 13:21:26 umbrel umbrel startup[16068]: services.lnd.ports contains an invalid type, it should be a number, or an object
Jun 11 13:21:26 umbrel umbrel startup[16068]: services.nginx.ports contains an invalid type, it should be a number, or an object
Jun 11 13:21:26 umbrel umbrel startup[16068]: services.lnd.ports value [‘9735:9735’, ‘:’, ‘:’] has non-unique elements
Jun 11 13:21:26 umbrel umbrel startup[16068]: Failed to start containers
Jun 11 13:21:26 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jun 11 13:21:26 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 11 13:21:26 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jun 11 13:21:31 umbrel systemd[1]: Stopped Umbrel Startup Service.
External storage service logs
– Logs begin at Sat 2022-06-11 13:11:36 UTC, end at Sat 2022-06-11 13:22:10 UTC. –
Jun 11 13:11:41 umbrel systemd[1]: Starting External Storage Mounter…
Jun 11 13:11:41 umbrel external storage mounter[485]: Running external storage mount script…
Jun 11 13:11:41 umbrel external storage mounter[485]: Found device “Samsung PSSD T7”
Jun 11 13:11:41 umbrel external storage mounter[485]: Blacklisting USB device IDs against UAS driver…
Jun 11 13:11:41 umbrel external storage mounter[485]: Rebinding USB drivers…
Jun 11 13:11:41 umbrel external storage mounter[485]: Checking USB devices are back…
Jun 11 13:11:41 umbrel external storage mounter[485]: Waiting for USB devices…
Jun 11 13:11:42 umbrel external storage mounter[485]: Waiting for USB devices…
Jun 11 13:11:43 umbrel external storage mounter[485]: Waiting for USB devices…
Jun 11 13:11:44 umbrel external storage mounter[485]: Checking if the device is ext4…
Jun 11 13:11:44 umbrel external storage mounter[485]: Yes, it is ext4
Jun 11 13:11:44 umbrel external storage mounter[485]: Checking if device contains an Umbrel install…
Jun 11 13:11:44 umbrel external storage mounter[485]: Yes, it contains an Umbrel install
Jun 11 13:11:44 umbrel external storage mounter[485]: Bind mounting external storage over local Umbrel installation…
Jun 11 13:11:44 umbrel external storage mounter[485]: Bind mounting external storage over local Docker data dir…
Jun 11 13:11:44 umbrel external storage mounter[485]: Bind mounting external storage to /swap
Jun 11 13:11:44 umbrel external storage mounter[485]: Bind mounting SD card root at /sd-card…
Jun 11 13:11:44 umbrel external storage mounter[485]: Checking Umbrel root is now on external storage…
Jun 11 13:11:45 umbrel external storage mounter[485]: Checking /var/lib/docker is now on external storage…
Jun 11 13:11:45 umbrel external storage mounter[485]: Checking /swap is now on external storage…
Jun 11 13:11:45 umbrel external storage mounter[485]: Setting up swapfile
Jun 11 13:11:46 umbrel external storage mounter[485]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 11 13:11:46 umbrel external storage mounter[485]: no label, UUID=3ad0e221-e99d-4c91-a737-3f8e5c5cd9f8
Jun 11 13:11:46 umbrel external storage mounter[485]: Checking SD Card root is bind mounted at /sd-root…
Jun 11 13:11:46 umbrel external storage mounter[485]: Starting external drive mount monitor…
Jun 11 13:11:46 umbrel external storage mounter[485]: Mount script completed successfully!
Jun 11 13:11:46 umbrel systemd[1]: Started External Storage Mounter.
Jun 11 13:11:57 umbrel external storage updater[904]: Fixing permissions
Jun 11 13:12:00 umbrel external storage updater[904]: Configuring new release
Jun 11 13:12:00 umbrel external storage updater[904]: ======================================
Jun 11 13:12:00 umbrel external storage updater[904]: =========== RECONFIGURING ============
Jun 11 13:12:00 umbrel external storage updater[904]: ========= UMBREL (mainnet) ===========
Jun 11 13:12:00 umbrel external storage updater[904]: Generating auth credentials
Jun 11 13:12:00 umbrel external storage updater[904]: Generating Tor password
Jun 11 13:12:08 umbrel external storage updater[904]: docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
Jun 11 13:12:08 umbrel external storage updater[904]: See ‘docker run --help’.
Jun 11 13:12:08 umbrel external storage updater[904]: == End Update Script 01-run.sh ==
Jun 11 13:12:08 umbrel external storage updater[904]: == Begin Update Script 02-run.sh ==
Jun 11 13:12:08 umbrel external storage updater[904]: =======================================
Jun 11 13:12:08 umbrel external storage updater[904]: =============== UPDATE ================
Jun 11 13:12:08 umbrel external storage updater[904]: ========= Stage: Post-update ==========
Jun 11 13:12:08 umbrel external storage updater[904]: == End Update Script 02-run.sh ==
Jun 11 13:12:08 umbrel external storage updater[904]: == Begin Update Script 03-run.sh ==
Jun 11 13:12:08 umbrel external storage updater[904]: =========== Stage: Success ============
Jun 11 13:12:08 umbrel external storage updater[904]: Removing backup
Jun 11 13:12:08 umbrel external storage updater[904]: Successfully installed Umbrel 0.5.0
Jun 11 13:12:08 umbrel external storage updater[904]: == End Update Script 03-run.sh ==
Jun 11 13:12:08 umbrel external storage updater[904]: Deleting cloned repository
Jun 11 13:12:08 umbrel external storage updater[904]: Removing lock
Jun 11 13:12:08 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
Umbrel logs
Bitcoin Core logs
LND logs
electrs logs
Tor logs
App logs
btc-rpc-explorer
ERROR: Couldn’t find env file: /home/umbrel/umbrel/.env
home-assistant
mempool
==== Result ====
