I go through all of the steps and can boot from the USB just fine. But after it flashes to my storage and I boot it back up it just boots me in to emergency mode. I have tinkered with my BIOS settings and have secure boot off. Now if I flash to an external HD and boot from there it runs but it does not migrate from my other external hd
If you want actual help you’ll need to tell folks what hardware, what attachments, etc. Nothing in you post says what you’re trying to install on.
Motherboard
ASRock A520M-HDV
Chipset
AMD A520
PROCESSOR
CPU Summary
AMD Ryzen 5 5600G (3.9GHz)
CPU Core
Cezanne
CPU Part Number
100-100000252MPK
CPU Socket
AM4
Level 2 Cache
3MB
Level 3 Cache
16MB
Turbo Boost Speed
Up to 4.4GHz
Cores
Six-Core
CPUs Supported
1
MEMORY
Total Memory
8GB
Memory Speed
DDR4-2666
Form Factor
288-pin DIMM
Maximum Memory Supported
32GB
SOLID STATE DRIVE
SSD Interface
NVMe
SSD Capacity
500GB
fixed after turning PCIe ARI Support to Auto in my UEFI
