Umbrel OS doesnt show second drive x86
The system settings doesn’t show the second drive.
when I check it onde terminal Sudo lsblk the second drive shows:
@umbrel:~$ lsblk
NAME MAJ
RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 200M 0 part /mnt/root/boot/efi
│ /boot/efi
├─sda2 8:2 0 9.8G 0 part /mnt/root
├─sda3 8:3 0 9.8G 0 part
└─sda4 8:4 0 445.9G 0 part /mnt/root/var/log
/var/log
/mnt/root/var/lib/docker
/var/lib/docker
/mnt/root/home
/home
/mnt/root/data
/data
sdb 8:16 0 465.8G 0 disk
sdc 8:32 1 0B 0 disk
how can I make it visible on the settings page
