Storage Management in Umbrel
New to Umbrel here. I loaded it on a older AMD Ryzen 2700 with a M.2 SSD and it had no issues with the install or using the 10G NIC. It saw my network shares and was able to join my Tailscale group.
But getting the included additional internal storage added to the portal seems to be a challenge.
I followed the instructions here:
It appears it did not like my UUID of the internal storage to mount and put Umbrel into an “emergency mode”. That is all fine because I can easily reinstall it, so I am not asking to fix that particular issue.
What I am looking for is a storage management container that will work in Umbrel. Are there any recommendations? Unraid uses a container to manage its volumes and in my examination of various container OS products they either recognize and mount any internal volumes from the start, or you have to mount them manually through a console like Umbrel.
Looking for feedback as I evaluate the OS. Thanks.
