Rebooting on 1.7.1 Removes Custom Services and Docker Permissions
On umbrelOS 1.7.1, I manually recreated custom /etc/systemd/system/*.service files that were previously part of my setup but were removed after updating.
This also affected related customizations such as:
  • Cloudflare Tunnel setup
  • Host-level automation
  • Docker permissions/group membership changes that broke existing docker-based aliases/scripts
For example, commands that previously worked via docker aliases began returning permission denied errors until permissions were manually corrected.
After recreating these items, they work again temporarily. However, after a normal reboot, the custom service files and related changes are no longer present again.
Is this expected behavior in 1.7.1, or a persistence bug?
1.7.1 is also re-writing /etc/fstab after every reboot
yes, super annoying
Yeah, this makes no sense to me at all on why they are doing this in the 1.7x versions. I understand trying to protect the OS but not completely not allowing customization???
At this time, I have no plans to upgrade off 1.5 until this is fix or a workaround becomes available.
And, if anyone comes up with a workaround to remove the “umbrelOS 1.7.2 is now availale to install” … I would sure be interested in that!
I might be curious but is this happening on any device, included Umbrel Home? Or just on “generic” devices?
All devices.
There’s a way to roll back to the previous version? I don’t like this downgrade
I’m moving to ZimaOS. I’m done
I was thinking that maybe they’re almost forcing their users to use their hardware and software, with no customisation whatsoever.
It’s a pity they don’t come to this forum anymore :frowning:
in my case, my little nuc box needs a special ethernet driver built (reaktek r8125) - umbrelos doesn’t properly support it out-of-box - but my previous (simple) steps to build the driver and install it no longer persist after reboot - meaning ethernet disappears.
THIS IS THE KEY:
sudo rugix-ctrl state overlay force-persist true
now i can do my driver build/install process and it survives rebooting.
then add a persistent repair hook (using /home/umbrel/umbrel/custom-hooks/pre-start) that reinstalls if driver disappears after an umbrel os update
I’m surprised this wasn’t mentioned in the release notes.
Thank you.
Yes. It’s very frustrating. For those affected by the fstab resets. The steps I took to fix the issue are detailed here: X86, after 1.7.3 update, directories created, mount points, fstab, wiped clean at every reboot
