Description
The Public Pool app loads the UI correctly but shows no data — it stays in an infinite loading spinner.
Root Cause
The nginx configuration at public-pool/data/proxy/nginx.conf is missing the WebSocket upgrade headers. Without them, the browser cannot establish a real-time WebSocket connection to the backend, so the UI never receives any data.
Current config:
server {
listen 80;
location / {
proxy_pass http://public-pool_web_1:80;
location ~* ^/api/ {
proxy_pass http://public-pool_server_1:2019;
Fixed config:
server {
listen 80;
location / {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
Environment
- umbrelOS: 1.7.4
- Hardware: PC x86 amd64
- Public Pool version: Package public-pool · GitHub
Verification
After applying the fix manually via SSH and reloading nginx, the UI loads all data correctly.
