Public Pool "Best Difficulty" resetting every day
Hey guys,
Im having the issue that Public Pool is always losing every day the best difficulty.
It starting always from 0, while my High Score is bigger. Is this normal? Like I tried Bassin for some days and couldnt see those issues. Normally my best difficulty should match the high score.
Its like my miner is reconnecting after some hours every day.
Do someone have the same issue?
Thanks.
No one any ideas?
Yeah, the online devices tab is “per session.” Every time you restart your miner, a new session ID gets generated, so you end up with a fresh best diff for that session. The top diff stays in memory for the High Scores tab.
I know it’s not really intuitive, but that’s just how it works.
Yep, @blockdyor has it right. The Best Difficulty under Online Devices is only the best share from the miner’s current Stratum session. Any disconnect or restart creates a new session, so that number starts from zero again.
High Scores is stored separately, which is why the previous 8.67G result remains while the current session shows 7.42M. The two values will only match again if the current session beats that stored score.
If this happens at about the same time every day, check the Uptime shown above the chart. If that also resets, the Public Pool app restarted. If the uptime keeps increasing, the miner or its network connection briefly disconnected and reconnected. Either way, the reset itself doesn’t affect the miner’s chance of finding a block; it’s just the current-session statistic starting over.
