Persistent Docker volume mount issues with Gluetun + qBittorrent / Transmission Kategorie: Technical Support / Docker / Portainer
Hi everyone,
I’m having a very persistent and frustrating issue with volume mounts when running torrent clients behind Gluetun on UmbrelOS.
Setup:
  • UmbrelOS (latest) on Umbrel Pro
  • Gluetun (WireGuard + Mullvad)
  • Tried both linuxserver/qbittorrent and linuxserver/transmission
  • Running with network_mode: “container:gluetun”
  • Managing stacks via Portainer
Problem:
Downloads are successfully completed inside the container, but never appear on the host filesystem / in the Umbrel File Manager under Downloads.
Volume mounts I tried:
YAML
- /home/umbrel/umbrel/home/Downloads:/downloads
- /home/umbrel/Downloads:/downloads
Commands executed on host:
Bash
mkdir -p /home/umbrel/Downloads
chown -R 1000:1000 /home/umbrel/Downloads
chmod -R 775 /home/umbrel/Downloads
# Also tried:
mkdir -p /home/umbrel/umbrel/home/Downloads/complete
chown -R 1000:1000 /home/umbrel/umbrel/home/Downloads
chmod -R 775 /home/umbrel/umbrel/home/Downloads
Inside the container:
Bash
mount | grep downloads     # returns nothing → mount not active
ls -la /downloads          # shows the downloaded files are there
The volume shows up correctly in Portainer’s Volumes tab, but the bind mount is not actually working inside the container.
Other official Umbrel apps (Immich, Jellyfin, etc.) have no problems with volume mounts.
Has anyone else experienced this issue recently?
Is there a known limitation with deep paths under /home/umbrel/umbrel/… or when using network_mode: “container:gluetun”?
Any help or workaround would be greatly appreciated.
Thanks!
PS: I new to all of this so I used AI do get it working also English is not my native language so this text is also translated by AI.
Possible solution: wrong Umbrel host path, not Gluetun
It sounds like the issue is probably not Gluetun and not network_mode: “container:gluetun”.
network_mode should only affect networking. It should not prevent Docker volume mounts from working.
The more likely problem is that the wrong Umbrel host path is being mounted.
Instead of using paths like:
try using Umbrel’s storage path:
/home/umbrel/umbrel/data/storage
For example:
- /home/umbrel/umbrel/data/storage/downloads:/downloads
Before redeploying the stack, create the folders on the host:
sudo mkdir -p /home/umbrel/umbrel/data/storage/downloads/complete
sudo mkdir -p /home/umbrel/umbrel/data/storage/downloads/incomplete
sudo chown -R 1000:1000 /home/umbrel/umbrel/data/storage/downloads
sudo chmod -R 775 /home/umbrel/umbrel/data/storage/downloads
Then configure the torrent client to use these paths inside the container:
/downloads/complete
For qBittorrent, the volumes should look like this:
volumes:
  • /home/umbrel/umbrel/data/storage/app-data/qbittorrent:/config
  • /home/umbrel/umbrel/data/storage/downloads:/downloads
And in qBittorrent settings:
Default Save Path: /downloads/complete
Keep incomplete torrents in: /downloads/incomplete
Also, if qBittorrent or Transmission is using Gluetun’s network namespace, the Web UI port needs to be exposed on the Gluetun container, not on the torrent container.
Example:
services:
gluetun:
image: qmcgaw/gluetun:latest
container_name: gluetun
cap_add:
  - NET_ADMIN
devices:
  - /dev/net/tun:/dev/net/tun
ports:
  - "8080:8080"      # qBittorrent Web UI
  - "6881:6881"
  - "6881:6881/udp"
volumes:
  - /home/umbrel/umbrel/data/storage/app-data/gluetun:/gluetun
environment:
  - VPN_SERVICE_PROVIDER=mullvad
  - VPN_TYPE=wireguard
  - WIREGUARD_PRIVATE_KEY=YOUR_PRIVATE_KEY_HERE
  - WIREGUARD_ADDRESSES=YOUR_WIREGUARD_ADDRESS_HERE
  - SERVER_COUNTRIES=Germany
  - TZ=Europe/Berlin
restart: unless-stopped
qbittorrent:
image: lscr.io/linuxserver/qbittorrent:latest
container_name: qbittorrent
network_mode: "service:gluetun"
depends_on:
  - gluetun
environment:
  - PUID=1000
  - PGID=1000
  - TZ=Europe/Berlin
  - WEBUI_PORT=8080
  - UMASK=002
volumes:
  - /home/umbrel/umbrel/data/storage/app-data/qbittorrent:/config
After changing the stack, he should redeploy/recreate the containers, not only restart them.
Then he can verify the real Docker mount with:
sudo docker inspect qbittorrent --format ‘{{range .Mounts}}{{println .Type .Source “->” .Destination}}{{end}}’
The correct result should show a bind mount like:
bind /home/umbrel/umbrel/data/storage/downloads → /downloads
If it shows volume instead of bind, then Docker/Portainer is still using a named volume, not the host folder.
Final mount test:
sudo docker exec -it qbittorrent sh -c ‘echo test > /downloads/complete/docker-mount-test.txt’
ls -lah /home/umbrel/umbrel/data/storage/downloads/complete
If docker-mount-test.txt appears on the host, the bind mount is working correctly.
So the most likely fix is to use:
instead of:
or:
