Ordinals using an Umbrel Full Node
Has anyone inscribed an ordinal using their Umbrel full node? If someone is, or thinks there is a way to, any tips?
I would sooner apply a patch to filter out the nonsense spam. Ordinals/inscription are an attack on the Bitcoin network.
You can add data to the blockchain since 2013 or so. There are also images in the ledger since that. The ordinals protocol just makes it a lot easier to use.
It’s not an “attack” it’s just another use case which currently brings many new user to bitcoin.
did you find out how to do it?
