Opening Channels Requests
I have one “slot” for up to 580k sat. Feel free to connect:
https://1ml.com/node/020ef33d350f9da8fe23ee6d215c1451cd8b96fc4acd46fdbe2e5368b6400c0013
I will be on 24/7 thank you in advance.
026e0fb9ed4ba8de383a59d7b088c2bae9375226fb933ab61e05d1a6c7382de0b5@jo5d5seychzxrf74obr4dhmto4at7ki2s2znxkbqe6i732yc4jhsuead.onion:9735
hit you with 0.018 BTC
Hey guys, still looking for inbound, will match. Node is Galway
Hi everyone looking to get some inbound capacity to my node. Will try my best to match in return. Cheers and happy routing!
https://1ml.com/node/0378e741889e9def95f488ad21d195d3357b28403527e5d3b4987e92e680b1ba53
Trying to balance some channels to improve inbound liquidity. Anyone use circular rebalance option in RTL? I tried but it fails every time. Either no route error or timeout error.
Try small amounts at a time like 10-20k. Also fees set to % of amount at 2%. Try to adjust amount and %fee after a successful to see what works. The amount depends on liquidity and how well your node is connected.
Loving my Umbrel! Would love some inbound liquidity please!
03394e5aec86daefdc6e376113ca6f9fb95c14397b8e83d0cdba7aaad1e5d8dea5@duxlckwuzwv4viymn433n2p6aqys2ubqao47hjxkiq6ffkfzgbix6sid.onion:9735
0304cb6754fa272c00f4934e67a314d3c4d709086ea6b9990e740a393f35b96db0@htgxmxmdmmbjrl7fz6ah7w6yish6dp2b4346zaznhwef7glu3wcueqyd.onion:9735 is dying for inbound liquidity :smile_cat:
027c5166b40423795c0fc41fc18c944dd95e070582f514450215ed1dc1d98c0afd@p4eqqnxjpihnt5egsrg447wk72xbzie5xhjfxfy4kkd4etcurwohdrad.onion:9735
Looking to just open any channels. Looking to keep fees as low as possible.
Hi everyone, i’m looking to open some 1M channels in case anyone is interested
020060ce06e5130c55900c4c4b0d6bc34e72f94d948854b6e0670f154472d014ec@kxpr7j4jpcaup7k6xbdj53mq2tdm6anukvz765satbqi7orjezj7qcad.onion:9735
I’ll connect with you
Thanks!
Channel open tx has been made for 1M sats my node is the following.
My New node works 24/7 stable, connect with 100000 sats to me and i will open a channel to you too with 100k sats
02c5bb1e603ac242721d230480ce45e3d6c819ffba04a3edfd594f58ce08305479@hj3lgktq5xiziwd7cug4ki5wo4qksl34i7t6mhgqk3vlya3pvmsei7yd.onion:9735
Love this!!
David
Would you be interested in a 1M connection?
If you use circular rebalance, you are shifting inbound liquidity from one channel to another. There has to be some inbound liquidity already. Also there may not be a route with large enough channels if you are trying to rebalance a large amount.
I’m up for a triangle
UmbrelReach
Opened one to you as well
1ML
I used the wrong words… fixed that. Thanks.
