Hi all, Officient, I saw your comment (in the thread, not this one) about the lightning network.plus site, and went there to start setting up triangles. Thanks for the heads up. I’d still like to open a triangle with you at some point, but it isnt pressing.
Doesn’t “need” to happen, but to provide the best opportunity for use, you would want to rebalance the channel.
Awesome. @jinja, you should have an inbound connection from me in place soon: https://mempool.space/tx/ca303e4f596b54a25e5cfa0fc3d35236f8c1ad98594c5a0eec120fa2f88a003e
Yes just saw it, thank you for closing the loop!
@CypherPoet and @jinja, do you want to do a triangle also? 0247bf4d37a1ffe2f04ca5df3c351339781b12d0320438de3250700392a00b70d1@jffshcfayq7cz6qbpuzszhd2topz6twagdglxpp2mkwnonezofjs67ad.onion:9735
I would say yes but I unfortunately don’t have any coins left ![]()
@chance144 I freed up some funds to create a triangle. I will open a channel with 1 million sats to your node and you have to open a channel to this node which is connected to me:
02e7a7d3c1e6055b7b7457d95e04d9bbd24f200fd4a58daca7beee7bc776e17440@twryyrdkmyvf4ppl35cneigibvi4uus4yuw2vm7hbtsdm6wuchli2cyd.onion:9735
Done. Now we need someone else? @Cyperpoet!! jump in!
Actually we don’t that node is connected to me so we are a full triangle ![]()
Oh sweet, that makes sense.
Channel opened. Please do the same:-)
02c54d97fb1dbad8419862dc757c0e76c9bb00bcc6784ad82f3c43be1fd482a106@fwbbhkqktvfqvas27hdd5ommgy4eu4wbtdvrpi5pbrpeoeyup34bgrad.onion:9735
Hi Jason I’m maxed out on liquidity at the moment. I will only be able to open channels in about 2 weeks. Hope that’s ok.
Do you want to open a channel? 1 million sats?
Feel free to open a channel to mine. Will be on 24/7. I’ll open back as I’m able to.
0382cd4617c280cc00c1c1589768f7a128d5a119ec26d4bf92b74751d0322351b6@twf35zypbdvv55vylwwfhstilsjuhpbfgft23qulpzo63bumky7xtvad.onion:9735
I’m just getting my lightning node setup. Would love it if anyone would create a channel with me. I’m willing to open channel in return. Node will be up 24x7.
02676da411bd1afc62df33152461b6d51b8da6a7381e379ae0f26119e0f44a5317@kkfhlukvdyucp25cwon44wa76f7pguh7t55rpj5khhgcko6vfeupviad.onion:9735
What size channel are you looking to open kobe1979?
Between 500k and 1M sats.
Gotcha… was looking for a little bigger channel (1.5 to 2M), but i’m sure someone will respond soon who’s looking for that size.
