Ollama openclaw config
I can’t make my OpenClaw to listen my local ollama models in my Umbrel Home
On telegram I do see it listed so I can actually change provider and select ollama and pick a model so it looks like what I have out I the OpenClaw JSON is accepted but in the end is always using my cloud models because it’s apparently not able to listen the local models
Is there any spec on how to configure it? I guess is the url I used as I puT Umbrel.local and maybe it cannot listen to that url within the same Umbrel
Any help will be appreciated
