Nextcloud broke after 25.0.1 upgrade
Probably, yes. I would try to find that directory and move the files somewhere else. And cross my fingers!!
This directory is normally located at umbrel/app-data/nextcloud/data/nextcloud/data/your_username
You probably need to type sudo su before
Hey folks,
It pains me to see this update (that I implemented) has not worked out. Nextcloud forced us to cycle through a few versions of Nextcloud to get 100% up-to-date and it looks like something has gone astray.
To help root cause the issue, could you post here the results of these commands:
docker logs --tail 100 nextcloud_web_1
cat ~/umbrel/app-data/nextcloud/data/nextcloud/config/config.php | grep version
tail -n 100 ~/umbrel/app-data/nextcloud/data/nextcloud/data/nextcloud.log
grep -wns "Updating app nextcloud..." ~/umbrel/logs/karen.log -A 1000
When posting these logs - can you triple check that there is nothing sensitive within the data?
Just to quickly answer some questions here:
Yes, this is normal, this is simply when the Docker image was created/built (you can see it’s pretty new).
Nextcloud runs using Docker containers in Umbrel, so we there are no Nextcloud related files/processes directly installed onto the server (except for data/state that these containers persist). So the installation is a bit different here due to using Docker.
I think this is unlikely an issue, as I tested the upgrade process on my machine and never encountered an issue here - but I’ll keep an open mind.
This isn’t a concern, docker ps is simply stating that port 80 is open for that container, not port 80 open on your server to access Nextcloud.
Please note, if you uninstall any app, it will also delete the data associated with it, including Nextcloud. So I would not suggest that as a resolution, unless you have first copied the data out of the Nextcloud app.
I’m also available on Telegram where I could help someone 1-1 so that I can also navigate the problem better and collect data to help ensure this doesn’t happen again.
umbrel@umbrel:~ $ docker logs --tail 100 nextcloud_web_1
Configuring Redis as session handler
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 10.21.0.17. Set the ‘ServerName’ directive globally to suppress this message
[Mon Dec 12 02:54:01.924174 2022] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.54 (Debian) PHP/8.0.25 configured – resuming normal operations
[Mon Dec 12 02:54:01.924414 2022] [core:notice] [pid 1] AH00094: Command line: ‘apache2 -D FOREGROUND’
10.21.0.6 - - [12/Dec/2022:02:55:01 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [12/Dec/2022:02:55:17 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - umbrel [12/Dec/2022:03:02:34 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:03:03:29 +0000] “PROPFIND /remote.php/dav/files/umbrel/ HTTP/1.1” 500 717 “-” “Mozilla/5.0 (Android) Nextcloud-android/3.23.0”
10.21.0.6 - umbrel [12/Dec/2022:03:11:52 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - - [12/Dec/2022:03:14:04 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [12/Dec/2022:03:14:21 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - umbrel [12/Dec/2022:03:21:10 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:03:30:28 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:03:39:46 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:03:49:04 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:03:58:22 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:04:07:40 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:04:16:58 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:04:26:16 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:04:35:34 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:04:44:52 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:04:54:10 +0000] “GET /status.php HTTP/1.1” 500 425 “-” “Mozilla/5.0 (Linux) mirall/3.6.4git (Nextcloud, org.kde.Platform-6.0.6-76060006-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)”
10.21.0.6 - umbrel [12/Dec/2022:14:28:31 +0000] “PROPFIND /remote.php/dav/files/umbrel/ HTTP/1.1” 500 717 “-” “Mozilla/5.0 (Android) Nextcloud-android/3.23.0”
10.21.0.6 - - [17/Dec/2022:21:57:13 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [17/Dec/2022:21:57:29 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [17/Dec/2022:21:57:44 +0000] “GET /favicon.ico HTTP/1.1” 404 670 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [17/Dec/2022:22:01:48 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [17/Dec/2022:22:01:56 +0000] “GET / HTTP/1.1” 500 717 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
[Tue Dec 20 01:37:20.979574 2022] [autoindex:error] [pid 43] [client 10.21.0.6:34022] AH01276: Cannot serve directory /var/www/html/apps/files/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive
10.21.0.6 - - [20/Dec/2022:01:37:20 +0000] “GET /apps/files/?dir=/&fileid=2 HTTP/1.1” 403 673 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
10.21.0.6 - - [20/Dec/2022:01:37:21 +0000] “GET /favicon.ico HTTP/1.1” 404 670 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
umbrel@umbrel:~ $ sudo cat ~/umbrel/app-data/nextcloud/data/nextcloud/config/config.php | grep version
[sudo] password for umbrel:
‘version’ => ‘22.2.10.2-patch’,
umbrel@umbrel:~ $ grep -wns “Updating app nextcloud…” ~/umbrel/logs/karen.log -A 1000
17014:Updating app nextcloud…
17015-Stopping app tailscale…
17016-Stopping app nextcloud…
17017- “tailscale”
17018- “tailscale”
17019-Stopping tailscale_web_1 …
17020-Stopping tailscale_tor_server_1 …
17021-Stopping tailscale_tor_server_1 … done
17022-Stopping nextcloud_cron_1 …
17023-Stopping nextcloud_web_1 …
17024-Stopping nextcloud_redis_1 …
17025-Stopping nextcloud_tor_server_1 …
17026-Stopping nextcloud_db_1 …
17027-Stopping nextcloud_app_proxy_1 …
17028-Stopping tailscale_web_1 … done
17029-Stopping nextcloud_tor_server_1 … done
17030-Removing tailscale_web_1 …
17031-Removing tailscale_tor_server_1 …
17032-Removing tailscale_web_1 … done
17033-Removing tailscale_tor_server_1 … done
17034-Going to remove tailscale_web_1, tailscale_tor_server_1
17035- “tailscale”
17036-Pulling images for app tailscale…
17037-Stopping nextcloud_app_proxy_1 … done
17038-Stopping nextcloud_web_1 … done
17039- “tailscale”
17040-Pulling web …
17041-Pulling tor_server …
17042-Pulling tor_server … pulling from lncm/tor
17043-Pulling tor_server … digest: sha256:aab30ebb496aa25934…
17044-Pulling tor_server … status: image is up to date for l…
17045-Pulling tor_server … done
17046-Pulling web … pulling from tailscale/tailscale
17047-Pulling web … already exists
17048-Pulling web … pulling fs layer
17049-Pulling web … pulling fs layer
17050-Pulling web … downloading (1.0%)
17051-Pulling web … downloading (1.0%)
17052-Pulling web … downloading (22.3%)
17053-Pulling web … downloading (7.2%)
17054-Pulling web … downloading (64.0%)
17055-Pulling web … downloading (13.4%)
17056-Pulling web … downloading (100.0%)
17057-Pulling web … download complete
17058-Pulling web … extracting (1.6%)
17059-Pulling web … downloading (19.7%)
17060-Pulling web … downloading (27.0%)
17061-Pulling web … extracting (12.6%)
17062-Pulling web … downloading (33.2%)
17063-Pulling web … extracting (42.6%)
17064-Pulling web … downloading (39.5%)
17065-Pulling web … extracting (82.1%)
17066-Pulling web … downloading (46.7%)
17067-Pulling web … extracting (97.9%)
17068-Pulling web … extracting (100.0%)
17069-Pulling web … downloading (52.9%)
17070-Pulling web … pull complete
17071-Pulling web … downloading (61.2%)
17072-Pulling web … downloading (70.4%)
17073-Pulling web … downloading (81.8%)
17074-Pulling web … downloading (91.1%)
17075-Pulling web … verifying checksum
17076-Pulling web … download complete
17077-Pulling web … extracting (1.1%)
17078-Pulling web … extracting (2.2%)
17079-Pulling web … extracting (8.9%)
17080-Pulling web … extracting (13.3%)
17081-Pulling web … extracting (18.9%)
17082-Pulling web … extracting (27.8%)
17083-Pulling web … extracting (37.8%)
17084-Pulling web … extracting (44.4%)
17085-Pulling web … extracting (51.1%)
17086-Pulling web … extracting (56.6%)
17087-Pulling web … extracting (62.2%)
17088-Pulling web … extracting (71.1%)
17089-Pulling web … extracting (84.4%)
17090-Pulling web … extracting (97.7%)
17091-Pulling web … extracting (100.0%)
17092-Pulling web … pull complete
17093-Pulling web … digest: sha256:b915f3d99b5b54ff93…
17094-Pulling web … status: downloaded newer image fo…
17095-Pulling web … done
17096-Starting app tailscale…
17097- “tailscale”
17098- “tailscale”
17099-Stopping nextcloud_cron_1 … done
17100-Creating tailscale_web_1 …
17101-Creating tailscale_tor_server_1 …
17102-Stopping nextcloud_redis_1 … done
17103-Creating tailscale_web_1 … done
17104-Stopping nextcloud_db_1 … done
17105-Creating tailscale_tor_server_1 … done
17106-Removing nextcloud_cron_1 …
17107-Removing nextcloud_web_1 …
17108-Removing nextcloud_redis_1 …
17109-Removing nextcloud_tor_server_1 …
17110-Removing nextcloud_db_1 …
17111-Removing nextcloud_app_proxy_1 …
17112-Removing nextcloud_cron_1 … done
17113-Removing nextcloud_redis_1 … done
17114-Removing nextcloud_tor_server_1 … done
17115-Removing nextcloud_web_1 … done
17116-Removing nextcloud_db_1 … done
17117-Removing nextcloud_app_proxy_1 … done
17118-Going to remove nextcloud_cron_1, nextcloud_web_1, nextcloud_redis_1, nextcloud_tor_server_1, nextcloud_db_1, nextcloud_app_proxy_1
17119- “tailscale”
17120-Pulling images for app nextcloud…
17121- “tailscale”
17122-Pulling redis …
17123-Pulling tor_server …
17124-Pulling app_proxy …
17125-Pulling db …
17126-Pulling web …
17127-Pulling cron …
17128-Pulling tor_server … pulling from lncm/tor
17129-Pulling redis … pulling from library/redis
17130-Pulling app_proxy … pulling from getumbrel/app-proxy
17131-Pulling tor_server … digest: sha256:aab30ebb496aa25934…
17132-Pulling tor_server … status: image is up to date for l…
17133-Pulling redis … digest: sha256:e10f55f92478715698…
17134-Pulling redis … status: image is up to date for r…
17135-Pulling app_proxy … digest: sha256:f7e5f2d8a2d42bb39a…
17136-Pulling app_proxy … status: image is up to date for g…
17137-Pulling tor_server … done
17138-Pulling redis … done
17139-Pulling app_proxy … done
17140-Pulling cron … pulling from library/nextcloud
17141-Pulling db … pulling from library/mariadb
17142-Pulling db … digest: sha256:dfcba5641bdbfd7cbf…
17143-Pulling db … status: image is up to date for m…
17144-Pulling db … done
17145-Pulling web … pulling from library/nextcloud
17146-Pulling cron … pulling fs layer
17147-Pulling cron … pulling fs layer
17148-Pulling cron … pulling fs layer
17149-Pulling cron … pulling fs layer
17150-Pulling cron … pulling fs layer
17151-Pulling cron … pulling fs layer
17152-Pulling cron … pulling fs layer
17153-Pulling cron … pulling fs layer
17154-Pulling cron … pulling fs layer
17155-Pulling cron … pulling fs layer
17156-Pulling cron … pulling fs layer
17157-Pulling cron … pulling fs layer
17158-Pulling cron … pulling fs layer
17159-Pulling cron … pulling fs layer
17160-Pulling cron … pulling fs layer
17161-Pulling cron … pulling fs layer
17162-Pulling cron … pulling fs layer
17163-Pulling cron … pulling fs layer
17164-Pulling cron … pulling fs layer
17165-Pulling cron … pulling fs layer
17166-Pulling cron … waiting
17167-Pulling cron … waiting
17168-Pulling cron … waiting
17169-Pulling cron … waiting
17170-Pulling cron … waiting
17171-Pulling cron … waiting
17172-Pulling cron … waiting
17173-Pulling cron … waiting
17174-Pulling cron … waiting
17175-Pulling cron … waiting
17176-Pulling cron … waiting
17177-Pulling cron … waiting
17178-Pulling cron … waiting
17179-Pulling cron … waiting
17180-Pulling cron … waiting
17181-Pulling cron … waiting
17182-Pulling web … pulling fs layer
17183-Pulling web … pulling fs layer
17184-Pulling web … pulling fs layer
17185-Pulling web … pulling fs layer
17186-Pulling web … pulling fs layer
17187-Pulling web … pulling fs layer
17188-Pulling web … pulling fs layer
17189-Pulling web … pulling fs layer
17190-Pulling web … pulling fs layer
17191-Pulling web … pulling fs layer
17192-Pulling web … pulling fs layer
17193-Pulling web … pulling fs layer
17194-Pulling web … pulling fs layer
17195-Pulling web … pulling fs layer
17196-Pulling web … pulling fs layer
17197-Pulling web … pulling fs layer
17198-Pulling web … pulling fs layer
17199-Pulling web … pulling fs layer
17200-Pulling web … pulling fs layer
17201-Pulling web … pulling fs layer
17202-Pulling web … waiting
17203-Pulling web … waiting
17204-Pulling web … waiting
17205-Pulling web … waiting
17206-Pulling web … waiting
17207-Pulling web … waiting
17208-Pulling web … waiting
17209-Pulling web … waiting
17210-Pulling web … waiting
17211-Pulling web … waiting
17212-Pulling web … waiting
17213-Pulling web … waiting
17214-Pulling web … waiting
17215-Pulling web … waiting
17216-Pulling web … waiting
17217-Pulling web … waiting
17218-Pulling web … waiting
17219-Pulling cron … downloading (100.0%)
17220-Pulling cron … verifying checksum
17221-Pulling web … downloading (100.0%)
17222-Pulling web … verifying checksum
17223-Pulling web … download complete
17224-Pulling cron … download complete
17225-Pulling cron … downloading (0.6%)
17226-Pulling web … downloading (0.6%)
17227-Pulling web … downloading (1.0%)
17228-Pulling cron … downloading (1.0%)
17229-Pulling cron … downloading (2.5%)
17230-Pulling web … downloading (2.5%)
17231-Pulling cron … downloading (5.2%)
17232-Pulling web … downloading (5.2%)
17233-Pulling cron … downloading (9.3%)
17234-Pulling web … downloading (9.3%)
17235-Pulling web … downloading (4.3%)
17236-Pulling cron … downloading (4.3%)
17237-Pulling web … downloading (14.5%)
17238-Pulling cron … downloading (14.5%)
17239-Pulling web … downloading (6.2%)
17240-Pulling cron … downloading (6.2%)
17241-Pulling web … downloading (18.6%)
17242-Pulling cron … downloading (18.6%)
17243-Pulling cron … downloading (7.4%)
17244-Pulling web … downloading (7.4%)
17245-Pulling web … downloading (100.0%)
17246-Pulling web … verifying checksum
17247-Pulling web … download complete
17248-Pulling cron … verifying checksum
17249-Pulling cron … download complete
17250-Pulling cron … downloading (22.7%)
17251-Pulling web … downloading (22.7%)
17252-Pulling web … downloading (9.3%)
17253-Pulling cron … downloading (9.3%)
17254-Pulling web … downloading (25.8%)
17255-Pulling cron … downloading (25.8%)
17256-Pulling web … downloading (11.1%)
17257-Pulling cron … downloading (11.1%)
17258-Pulling web … downloading (29.9%)
17259-Pulling cron … downloading (29.9%)
17260-Pulling web … downloading (34.0%)
17261-Pulling cron … downloading (34.0%)
17262-Pulling cron … downloading (12.3%)
17263-Pulling web … downloading (12.3%)
17264-Pulling cron … downloading (39.2%)
17265-Pulling web … downloading (39.2%)
17266-Pulling cron … downloading (14.2%)
17267-Pulling web … downloading (14.2%)
17268-Pulling cron … downloading (1.0%)
17269-Pulling web … downloading (1.0%)
17270-Pulling cron … downloading (44.4%)
17271-Pulling web … downloading (44.4%)
17272-Pulling cron … downloading (16.0%)
17273-Pulling web … downloading (16.0%)
17274-Pulling web … downloading (7.3%)
17275-Pulling cron … downloading (7.3%)
17276-Pulling web … downloading (49.6%)
17277-Pulling cron … downloading (49.6%)
17278-Pulling web … downloading (17.3%)
17279-Pulling cron … downloading (17.3%)
17280-Pulling web … downloading (11.4%)
17281-Pulling cron … downloading (11.4%)
17282-Pulling web … downloading (52.7%)
17283-Pulling cron … downloading (52.7%)
17284-Pulling web … downloading (18.5%)
17285-Pulling cron … downloading (18.5%)
17286-Pulling web … downloading (16.7%)
17287-Pulling cron … downloading (16.7%)
17288-Pulling web … downloading (55.8%)
17289-Pulling cron … downloading (55.8%)
17290-Pulling web … downloading (19.8%)
17291-Pulling cron … downloading (19.8%)
17292-Pulling web … downloading (22.9%)
17293-Pulling cron … downloading (22.9%)
17294-Pulling web … downloading (58.9%)
17295-Pulling cron … downloading (58.9%)
17296-Pulling web … downloading (30.1%)
17297-Pulling cron … downloading (30.1%)
17298-Pulling web … downloading (21.6%)
17299-Pulling cron … downloading (21.6%)
17300-Pulling web … downloading (64.0%)
17301-Pulling cron … downloading (64.0%)
17302-Pulling web … downloading (37.4%)
17303-Pulling cron … downloading (37.4%)
17304-Pulling web … downloading (23.5%)
17305-Pulling cron … downloading (23.5%)
17306-Pulling cron … downloading (68.2%)
17307-Pulling web … downloading (68.2%)
17308-Pulling web … downloading (44.7%)
17309-Pulling cron … downloading (44.7%)
17310-Pulling cron … downloading (25.3%)
17311-Pulling web … downloading (25.3%)
17312-Pulling web … downloading (73.3%)
17313-Pulling cron … downloading (73.3%)
17314-Pulling web … downloading (52.0%)
17315-Pulling cron … downloading (52.0%)
17316-Pulling cron … downloading (27.2%)
17317-Pulling web … downloading (27.2%)
17318-Pulling web … downloading (77.5%)
17319-Pulling cron … downloading (77.5%)
17320-Pulling web … downloading (59.2%)
17321-Pulling cron … downloading (59.2%)
17322-Pulling web … downloading (81.6%)
17323-Pulling web … downloading (29.1%)
17324-Pulling cron … downloading (29.1%)
17325-Pulling web … downloading (66.5%)
17326-Pulling cron … downloading (81.6%)
17327-Pulling cron … downloading (66.5%)
17328-Pulling web … downloading (71.6%)
17329-Pulling cron … downloading (71.6%)
17330-Pulling web … downloading (84.7%)
17331-Pulling cron … downloading (84.7%)
17332-Pulling web … downloading (30.3%)
17333-Pulling cron … downloading (30.3%)
17334-Pulling web … downloading (75.8%)
17335-Pulling cron … downloading (75.8%)
17336-Pulling web … downloading (87.8%)
17337-Pulling cron … downloading (87.8%)
17338-Pulling web … downloading (31.5%)
17339-Pulling cron … downloading (31.5%)
17340-Pulling web … downloading (81.0%)
17341-Pulling cron … downloading (81.0%)
17342-Pulling web … downloading (90.9%)
17343-Pulling cron … downloading (90.9%)
17344-Pulling web … downloading (32.8%)
17345-Pulling cron … downloading (32.8%)
17346-Pulling web … downloading (88.2%)
17347-Pulling cron … downloading (88.2%)
17348-Pulling cron … downloading (94.0%)
17349-Pulling web … downloading (94.0%)
17350-Pulling cron … downloading (34.0%)
17351-Pulling web … downloading (34.0%)
17352-Pulling web … downloading (94.5%)
17353-Pulling cron … downloading (94.5%)
17354-Pulling web … downloading (98.1%)
17355-Pulling cron … downloading (98.1%)
17356-Pulling cron … verifying checksum
17357-Pulling cron … download complete
17358-Pulling web … verifying checksum
17359-Pulling web … download complete
17360-Pulling cron … downloading (35.2%)
17361-Pulling web … downloading (35.2%)
17362-Pulling web … verifying checksum
17363-Pulling cron … verifying checksum
17364-Pulling web … download complete
17365-Pulling cron … download complete
17366-Pulling web … downloading (36.5%)
17367-Pulling cron … downloading (36.5%)
17368-Pulling cron … downloading (37.7%)
17369-Pulling web … downloading (37.7%)
17370-Pulling web … extracting (1.1%)
17371-Pulling cron … extracting (1.1%)
17372-Pulling web … downloading (39.6%)
17373-Pulling cron … downloading (39.6%)
17374-Pulling web … extracting (5.4%)
17375-Pulling cron … extracting (5.4%)
17376-Pulling web … extracting (8.7%)
17377-Pulling cron … extracting (8.7%)
17378-Pulling web … downloading (41.4%)
17379-Pulling cron … downloading (41.4%)
17380-Pulling web … downloading (100.0%)
17381-Pulling web … download complete
17382-Pulling cron … verifying checksum
17383-Pulling cron … download complete
17384-Pulling web … downloading (100.0%)
17385-Pulling web … verifying checksum
17386-Pulling cron … downloading (100.0%)
17387-Pulling web … download complete
17388-Pulling cron … verifying checksum
17389-Pulling cron … download complete
17390-Pulling web … extracting (9.8%)
17391-Pulling cron … extracting (9.8%)
17392-Pulling web … downloading (43.3%)
17393-Pulling cron … downloading (43.3%)
17394-Pulling web … downloading (44.5%)
17395-Pulling cron … downloading (44.5%)
17396-Pulling web … extracting (14.2%)
17397-Pulling cron … extracting (14.2%)
17398-Pulling web … downloading (45.8%)
17399-Pulling cron … downloading (45.8%)
17400-Pulling cron … extracting (17.4%)
17401-Pulling web … extracting (17.4%)
17402-Pulling web … downloading (47.0%)
17403-Pulling cron … downloading (47.0%)
17404-Pulling cron … extracting (19.6%)
17405-Pulling web … extracting (19.6%)
17406-Pulling web … downloading (100.0%)
17407-Pulling cron … downloading (100.0%)
17408-Pulling cron … verifying checksum
17409-Pulling web … verifying checksum
17410-Pulling cron … download complete
17411-Pulling web … download complete
17412-Pulling web … downloading (1.0%)
17413-Pulling cron … downloading (1.0%)
17414-Pulling web … downloading (48.9%)
17415-Pulling cron … downloading (48.9%)
17416-Pulling cron … extracting (20.7%)
17417-Pulling web … extracting (20.7%)
17418-Pulling web … downloading (49.5%)
17419-Pulling cron … downloading (49.5%)
17420-Pulling web … downloading (4.3%)
17421-Pulling cron … downloading (4.3%)
17422-Pulling web … extracting (22.9%)
17423-Pulling cron … extracting (22.9%)
17424-Pulling web … downloading (50.7%)
17425-Pulling cron … downloading (50.7%)
17426-Pulling web … downloading (7.6%)
17427-Pulling cron … downloading (7.6%)
17428-Pulling web … extracting (25.1%)
17429-Pulling cron … extracting (25.1%)
17430-Pulling web … downloading (52.0%)
17431-Pulling cron … downloading (52.0%)
17432-Pulling web … downloading (10.8%)
17433-Pulling cron … downloading (10.8%)
17434-Pulling web … extracting (27.2%)
17435-Pulling cron … extracting (27.2%)
17436-Pulling cron … downloading (53.2%)
17437-Pulling web … downloading (53.2%)
17438-Pulling web … downloading (1.0%)
17439-Pulling cron … downloading (1.0%)
17440-Pulling web … downloading (13.0%)
17441-Pulling cron … downloading (13.0%)
17442-Pulling web … extracting (29.4%)
17443-Pulling cron … extracting (29.4%)
17444-Pulling web … downloading (7.7%)
17445-Pulling cron … downloading (7.7%)
17446-Pulling web … downloading (54.4%)
17447-Pulling cron … downloading (54.4%)
17448-Pulling web … downloading (16.1%)
17449-Pulling cron … downloading (16.1%)
17450-Pulling cron … extracting (32.7%)
17451-Pulling web … extracting (32.7%)
17452-Pulling web … downloading (16.4%)
17453-Pulling cron … downloading (16.4%)
17454-Pulling web … downloading (55.7%)
17455-Pulling cron … downloading (55.7%)
17456-Pulling web … extracting (36.0%)
17457-Pulling cron … extracting (36.0%)
17458-Pulling web … downloading (18.2%)
17459-Pulling web … downloading (25.3%)
17460-Pulling cron … downloading (18.2%)
17461-Pulling cron … downloading (25.3%)
17462-Pulling web … downloading (57.5%)
17463-Pulling cron … downloading (57.5%)
17464-Pulling web … downloading (36.4%)
17465-Pulling cron … downloading (36.4%)
17466-Pulling web … downloading (21.4%)
17467-Pulling cron … extracting (39.2%)
17468-Pulling web … extracting (39.2%)
17469-Pulling cron … downloading (21.4%)
17470-Pulling web … downloading (58.8%)
17471-Pulling cron … downloading (58.8%)
17472-Pulling web … downloading (46.5%)
17473-Pulling cron … downloading (46.5%)
17474-Pulling web … extracting (42.5%)
17475-Pulling cron … extracting (42.5%)
17476-Pulling cron … downloading (24.5%)
17477-Pulling web … downloading (24.5%)
17478-Pulling web … downloading (56.6%)
17479-Pulling cron … downloading (56.6%)
17480-Pulling web … downloading (60.6%)
17481-Pulling cron … downloading (60.6%)
17482-Pulling cron … downloading (27.7%)
17483-Pulling web … downloading (27.7%)
17484-Pulling cron … extracting (44.7%)
17485-Pulling web … extracting (44.7%)
17486-Pulling web … downloading (62.1%)
17487-Pulling cron … downloading (62.1%)
17488-Pulling web … downloading (61.8%)
17489-Pulling cron … downloading (61.8%)
17490-Pulling web … downloading (29.8%)
17491-Pulling cron … downloading (29.8%)
17492-Pulling web … extracting (46.9%)
17493-Pulling cron … extracting (46.9%)
17494-Pulling web … downloading (73.1%)
17495-Pulling cron … downloading (73.1%)
17496-Pulling web … downloading (63.1%)
17497-Pulling cron … downloading (63.1%)
17498-Pulling web … extracting (49.0%)
17499-Pulling cron … extracting (49.0%)
17500-Pulling web … downloading (83.1%)
17501-Pulling cron … downloading (83.1%)
17502-Pulling web … downloading (32.9%)
17503-Pulling cron … downloading (32.9%)
17504-Pulling web … downloading (64.3%)
17505-Pulling cron … downloading (64.3%)
17506-Pulling web … downloading (96.3%)
17507-Pulling cron … downloading (96.3%)
17508-Pulling web … extracting (51.2%)
17509-Pulling cron … extracting (51.2%)
17510-Pulling web … verifying checksum
17511-Pulling cron … verifying checksum
17512-Pulling web … download complete
17513-Pulling cron … download complete
17514-Pulling web … downloading (36.1%)
17515-Pulling cron … downloading (36.1%)
17516-Pulling web … downloading (66.2%)
17517-Pulling cron … downloading (66.2%)
17518-Pulling web … extracting (55.6%)
17519-Pulling cron … extracting (55.6%)
17520-Pulling web … downloading (68.1%)
17521-Pulling web … downloading (39.2%)
17522-Pulling cron … downloading (68.1%)
17523-Pulling cron … downloading (39.2%)
17524-Pulling web … extracting (59.9%)
17525-Pulling cron … extracting (59.9%)
17526-Pulling web … extracting (64.3%)
17527-Pulling cron … extracting (64.3%)
17528-Pulling web … downloading (42.4%)
17529-Pulling web … downloading (69.9%)
17530-Pulling cron … downloading (42.4%)
17531-Pulling cron … downloading (69.9%)
17532-Pulling web … extracting (68.7%)
17533-Pulling cron … extracting (68.7%)
17534-Pulling web … downloading (44.5%)
17535-Pulling cron … downloading (44.5%)
17536-Pulling web … downloading (71.8%)
17537-Pulling cron … downloading (71.8%)
17538-Pulling web … downloading (30.9%)
17539-Pulling web … downloading (100.0%)
17540-Pulling cron … downloading (30.9%)
17541-Pulling cron … downloading (100.0%)
17542-Pulling web … verifying checksum
17543-Pulling cron … verifying checksum
17544-Pulling web … download complete
17545-Pulling cron … download complete
17546-Pulling web … extracting (73.0%)
17547-Pulling cron … extracting (73.0%)
17548-Pulling web … downloading (47.6%)
17549-Pulling cron … downloading (47.6%)
17550-Pulling web … downloading (73.6%)
17551-Pulling cron … downloading (73.6%)
17552-Pulling cron … downloading (52.9%)
17553-Pulling web … downloading (52.9%)
17554-Pulling web … extracting (76.3%)
17555-Pulling cron … extracting (76.3%)
17556-Pulling cron … downloading (74.9%)
17557-Pulling web … downloading (74.9%)
17558-Pulling cron … downloading (63.6%)
17559-Pulling web … downloading (63.6%)
17560-Pulling web … extracting (78.5%)
17561-Pulling cron … extracting (78.5%)
17562-Pulling cron … downloading (76.1%)
17563-Pulling web … downloading (76.1%)
17564-Pulling web … downloading (71.2%)
17565-Pulling cron … downloading (71.2%)
17566-Pulling cron … downloading (77.4%)
17567-Pulling web … downloading (77.4%)
17568-Pulling web … extracting (82.8%)
17569-Pulling cron … extracting (82.8%)
17570-Pulling web … downloading (78.6%)
17571-Pulling cron … downloading (78.6%)
17572-Pulling web … downloading (100.0%)
17573-Pulling cron … downloading (100.0%)
17574-Pulling cron … verifying checksum
17575-Pulling web … verifying checksum
17576-Pulling cron … download complete
17577-Pulling web … download complete
17578-Pulling web … downloading (78.6%)
17579-Pulling cron … downloading (78.6%)
17580-Pulling cron … downloading (88.1%)
17581-Pulling web … downloading (88.1%)
17582-Pulling cron … extracting (85.0%)
17583-Pulling web … extracting (85.0%)
17584-Pulling web … downloading (99.7%)
17585-Pulling cron … downloading (99.7%)
17586-Pulling web … verifying checksum
17587-Pulling cron … verifying checksum
17588-Pulling web … download complete
17589-Pulling cron … download complete
17590-Pulling web … downloading (80.5%)
17591-Pulling cron … downloading (80.5%)
17592-Pulling web … downloading (82.3%)
17593-Pulling cron … downloading (82.3%)
17594-Pulling cron … extracting (87.2%)
17595-Pulling web … extracting (87.2%)
17596-Pulling web … downloading (84.2%)
17597-Pulling cron … downloading (84.2%)
17598-Pulling cron … downloading (85.1%)
17599-Pulling web … downloading (85.1%)
17600-Pulling cron … downloading (100.0%)
17601-Pulling web … downloading (100.0%)
17602-Pulling cron … verifying checksum
17603-Pulling web … verifying checksum
17604-Pulling cron … download complete
17605-Pulling web … download complete
17606-Pulling cron … extracting (88.3%)
17607-Pulling web … extracting (88.3%)
17608-Pulling web … downloading (85.4%)
17609-Pulling cron … downloading (85.4%)
17610-Pulling web … downloading (86.7%)
17611-Pulling cron … downloading (86.7%)
17612-Pulling web … downloading (1.1%)
17613-Pulling web … extracting (91.6%)
17614-Pulling cron … extracting (91.6%)
17615-Pulling cron … downloading (1.1%)
17616-Pulling web … downloading (87.9%)
17617-Pulling cron … downloading (87.9%)
17618-Pulling web … downloading (26.9%)
17619-Pulling cron … downloading (26.9%)
17620-Pulling cron … extracting (93.7%)
17621-Pulling web … extracting (93.7%)
17622-Pulling web … downloading (89.2%)
17623-Pulling cron … downloading (89.2%)
17624-Pulling web … downloading (67.3%)
17625-Pulling cron … downloading (67.3%)
17626-Pulling web … verifying checksum
17627-Pulling cron … verifying checksum
17628-Pulling web … download complete
17629-Pulling cron … download complete
17630-Pulling web … downloading (90.4%)
17631-Pulling cron … downloading (90.4%)
17632-Pulling cron … downloading (1.0%)
17633-Pulling web … downloading (1.0%)
17634-Pulling web … extracting (94.8%)
17635-Pulling cron … extracting (94.8%)
17636-Pulling web … downloading (91.6%)
17637-Pulling cron … downloading (91.6%)
Truncated, it keeps going with downloading/extracting messages, nothing more interesting.
For the nextcloud.log file, the command you asked for yielded 18MB of data! Here are the last several rows:
{“reqId”:“WUoG1G2F6LyIh0PLQqxZ”,“level”:3,“time”:“2022-12-09T14:20:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“userAgent”:"–",“version”:“22.2.10.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:100,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",100]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:[]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[]},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:150,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
{“reqId”:“9M4r1usYXKxEhCs5OSTe”,“level”:3,“time”:“2022-12-10T14:25:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#98”,“userAgent”:"–",“version”:“22.2.10.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#98”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:98,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",98]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:[]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[]},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:150,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
{“reqId”:“9M4r1usYXKxEhCs5OSTe”,“level”:3,“time”:“2022-12-10T14:25:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“userAgent”:"–",“version”:“22.2.10.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:100,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",100]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:[]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[]},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:150,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
{“reqId”:“zwxt4MsejASvmxjsKLQz”,“level”:3,“time”:“2022-12-11T14:30:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#98”,“userAgent”:"–",“version”:“22.2.10.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#98”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:98,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",98]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:[]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[]},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:150,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
{“reqId”:“zwxt4MsejASvmxjsKLQz”,“level”:3,“time”:“2022-12-11T14:30:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“userAgent”:"–",“version”:“22.2.10.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:100,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",100]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:[]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[]},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:150,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
I also tried those commands, and it seems that I have the same results as @kenwdelong
Ok guys, i need help to get out of this :sleepy:
Steps i tried:
1.) I tried to save my data, but (dont know why) i cant acces my external storage wich is connected to my umbrel. when i plug it into my pc, i see the storage in the equipment manager, seems to be ok. I also Tried to open it Via diskmgmt.msc. But the option to open the Storage is greyed out.
2.) I plugged it back to my Raspberry. Umbrel boots normally. So i tried to get acces via Putty to my Data Folder of Nextcloud and wanted to copy the folder via scp -c command (i am able to connect):
scp -C umbrel@192.168.178.21 /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/data/umbrel/files XXX@192.168.178.24:C:/users/XXX/Desktop/Kopie
then i get the following error:
ssh: connect to host 192.168.178.24 port 22: Connection timed out
lost connection
it would be so nice if someone helps me to save my 50 gigs of lifetime photos out of the nextcloud.
This is lame, but have you tried scp in both directions? scp from Windows -> Umbrel, and also log into Umbrel and try Umbrel->Windows?
Hello, you can try to use winscp. Probably a new program will use a new certificate.
You have too to gain access to data folder which is unavailable.
/home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/ and sudo chmod 775 data/
After you have just to download the data folder (right clic)
I Hope it will work
@nevets963 - what’s your Telegram id?
@stevenbriscoe (Steven Briscoe)
Hey! first i had some problems, but it was my fault. i started the download! thank you so much! @er9871
ps: it worked with chmod 777 data/
I finally gave up and deleted and reinstalled NextCloud from the UI.
I made a backup of the files at /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/data/umbrel/files
I found I couldn’t simply restore them by copying them back; I had to re-upload them from the client (I guess that puts them in the database).
I am having this same exact issue. Is there any resolution to this? I don’t want to lose all my data here.
Like many others in here, the upgrade of the Nextcloud app to v25 was horrible. App no longer worked. Getting the same error as everyone else here, “Internal Server Error”, etc. Unfortunately, I found no fix besides a reinstall. But in this post I’ll do my best to compile everything I’ve found/learned to give you a guide on how to reinstall without losing all your data already in there. Seeing as this problem has been ongoing for over a month now, doesn’t seem like a hot-fix is coming, or will come by Umbrel.
I even reached out to support from Umbrel regarding the issue and the very first message I got back from the support representative was: “Uninstall the app then reinstall it and see if you can login.” That was it. No mention of “hey, this will wipe all your data. Here’s a way to back it up,” nothing.
Another issue that is occurring on the Nextcloud v25 besides a completely broken install/update is a broken client. After reinstalling and getting Nextcloud to work on Umbrel, the sync client would hang up, freeze, and cause a massive memory leak and CPU usage and not sync the files. I’ll explain how to fix that as well here. So let’s get started…
Nextcloud v25 Update Fix
First, you need an FTP to get into the Umbrel to get/backup your files stored there. Download WinSCP to do this. Upon starting WinSCP you’ll be presented with some information you need to input. For “File protocol:” choose “SFTP.” For “Host name:” that will be your Umbrel IP/domain (ex: 123.456.7.89). For “Port number:” set to “22.” Username is clearly your username, likely “umbrel” and then finally your password. Click Login.
Once you’re in, navigate to the following path:
This is where we will find our data stored on the Umbrel’s Nextcloud, inside the “data” folder. But you likely won’t have the permissions to view/open that directory.
So let’s now open Windows PowerShell and SSH into our umbrel to set permissions. To do so, open PowerShell and in the command line type
ssh umbrel@umbrel.local
Next it will ask for your password, type your password & hit enter. You should now be in. Now in the command line enter:
cd /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/
followed by:
It should ask for the password again, type it & hit enter - you should now be able to view/open that “data” folder in WinSCP. If not, enter the command:
again after typing your password.
Enter that “data” folder and you should now see your user account(s) you have in Nextcloud. On the left-hand side of the WinSCP window is where your data will be downloaded too, so if you want to put this somewhere specific, like your Desktop, or a different folder, navigate there on the left-hand side of the window. You could now just right-click & download the entire “data” folder, or just right-click & download the user account(s) you want. Once the download is complete, all your data is now secured locally.
At this point, you are now safe to go to your Umbrel dashboard, “Manage Apps” and uninstall/delete the Nextcloud app. Once removed, you can now go to the App Store and “Install” it. This will now install Nextcloud v25 minus the issue(s). If you don’t use the Nextcloud desktop client to sync your files, you can just manually drag & drop to reupload your data here as you’d like. If you use the Nextcloud desktop client to sync your files, proceed below.
Nextcloud Client Syncing Issue Fix
You may need to reconfigure the Nextcloud desktop client here (such as username and password) to get it connected again to your Umbrel’s Nextcloud installation. Once connected, don’t start to sync yet. If you do, some files will get uploaded, but the client will likely freeze/hangup and cause issues and never finish syncing. You can try, and if it works, you’re lucky! If not, proceed below.
We need to change two things. In the Nextcloud client, go to the “Network” settings and ensure your “Download bandwidth” & “Upload bandwidth” are both set to “No limit.” Once set, we need to go back into the WinSCP window. Navigate to
/home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/config
In here we need to edit the “config.php” file, however it’s likely due to permissions you won’t be able to open it. If that’s the case, we need to go back to PowerShell and set some permissions.
In PowerShell enter the following:
cd /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/config
followed by:
sudo chmod 777 config.php
At this point we should now be able to open the “config.php” file in WinSCP. Open that, and at the bottom of the file, AFTER
‘updater.secret’ => blahblahblah,
Add in
‘bulkupload.enabled’ => false,
And save that file. In WinSCP you should see it reuploads the newly edited file at the bottom of the window, and if not and you get some message about deleting and reuploading, do that.
At this point, double check the permissions on the “config.php” file by right-clicking and selecting “Properties” and ensure the “Permissions” are set to “0777.” If so, you should now be able to begin syncing with the Nextcloud client to your Nextcloud server on Umbrel without any issues. You will likely need to reconfigure your upload/sync paths as desired, but all should be well at this point. Begin syncing and you’re done.
This is the path I took to resolve both the above-mentioned issues. If you try this & need further help feel free to reach out. If you try this and it works for you too, let us know!
Hi Lation, Thanks for the great instructions. I managed to copy all my Nextcloud data to my desktop. I’ve deleted and re-installed Nextcloud using the umbrel app and it’s running as expected. When I try and copy my data back over to nextcloud, I get a message that I don’t have permission. I tried the instructions you provided to open access to nextcloud data, but still can’t manage to drag the data folder back over. Any ideas? I’m not tech savvy.
thx noah
Hey man, you’re welcome. So it sounds like you may be trying to re-upload your data back through the FTP client, WinSCP? If so, I wouldn’t recommend that. I would just go to your Nextcloud domain, and upload files as you normally would via the website (drag and drop or however). If that’s not what you meant, let me know!
Thanks Lation. Yes…I was trying to upload via Winscp. I’ll try and upload now via the Nextcloud direct. Many thanks
Noah
