The set up assistant prompts to plug ethernet into ANY available port, does that mean I can plug into WAN port instead of the LAN ?
Thank you for your time.
Do you know the difference between WAN and LAN?
Yes, not a length. My understanding is that WAN is used to extend network beyond LAN. I am assuming no is the answer, just thought I would check with the cyber wizards first.
