Is there a way to reset my password?
I can’t remember my password to log into umbrel.local. I have my recovery phase written down but I’m not sure how to reset my chosen password when logging into to umbrel.local.
Is it even possible to reset or do I need to set up a new node and start again?
Hey @Hof apparently the easier way is to reset your microSD with a fresh umbrel installation, you can read more here and here… However, before that you have 4 options to try
Hope you have a backup of your seedPhrase. if you had any channel open and want a backup of the channels you should DM the umbrel’s team
