HOW-TO Connect to NAS or SMB Share
This guide will walk you through connecting a SMB share to Umbrel for use with Plex, Sonarr, Radarr, Transmission and others. Useful if your Umbrel Server has limited space or you just want to use a NAS you already have.
*** Please note I do know know if this will survive an update. If one of the Dev’s could confirm this ***
Connect to your Umbrel Server using Putty or your SSH Client of choice.
Run the following command to install CIFS utilities:
sudo apt install cifs-utils
Enter your password to proceed.
Now we will create the folder to map the SMB share to in the Downloads folder.
(Reason we use Downloads as all docker images that I have tested so far have access to this folder.)
sudo mkdir /home/umbrel/umbrel/home/Downloads/Multimedia
(Change Multimedia to whatever you want it called.)
Now we will create the credential file to connect to the SMB Share. These are typically the username and password for your NAS. Test and confirm first.
sudo nano /root/.smbcredentials
Add the following lines:
username=smb_username
password=smb_password
Remember to replace the username and password with your SMB Share details.
Press Ctrl+O to save, then Ctrl+X to exit.
Now we will test the connection to ensure the SMB share mounts
sudo mount -t cifs -o rw,vers=3.0,credentials=/root/.smbcredentials //192.168.0.10/Multimedia /home/umbrel/umbrel/home/Downloads/Multimedia
Remember to change //192.168.0.10/Multimedia to whatever your SMB Share is.
Open Umbrel file browser and make sure you can browse the folder.
If all is well, lets jump back into Putty and add the connection to FSTAB to make sure it mounts on boot.
sudo nano /etc/fstab
Add the following to the end of the file:
# network share mount
//192.168.0.10/Multimedia /home/umbrel/umbrel/home/Downloads/Multimedia cifs credentials=/root/.smbcredentials,uid=1000,user 0 0
At this stage we will reboot the Umbrel Server. Either run “systemctl reboot” in Putty or reboot from Umbrel’s UI.
Once rebooted confirm the SMB Share is mounted and you can access the files.
Proceed to edit the paths in your apps like Plex, Radarr and Transmission.
Plex:
Radarr:
Transmission:
