Create a VPS and login via SSH
Remember to block all incoming traffic on ports except 22 (ssh) and 51820 (wireguard) at firewall level.
Urbit likes to have port 34343 as TCP open as well
Run one at a time
sudo su
sudo ufw status
sudo ufw disable # We reroute everything through to the host
sudo apt-get update
sudo apt-get install -y tmux
sudo apt-get install -y git
sudo apt-get install -y vim
sudo apt-get install -y htop
sudo -v ; curl https://rclone.org/install.sh | sudo bash
Install DentropyCloud Wireguard
git clone https://gitlab.com/dentropy/dentropycloud-traefik.git
cd ./dentropycloud-traefik
cp env_example .env
vim .env
# Add IP address of server as for MY_DOMAIN
bash generate_docker_compose.sh
cd ./apps-umbrel/wireguard
docker-compose up -d
# GET IP ADDRESS OF HOST, THIS IS IMPORANT, WRITE IT DOWN
echo $(ifconfig | grep -E "([0-9]{1,3}\.){3}[0-9]{1,3}" | grep -v 127.0.0.1 | awk '{ print $2 }' | cut -f2 -d: | head -n1)
# NOTE DOWN THIS IP ADDRESS, it should be
# 10.21.0.1
Copy a config
# All wireguard configs
# Please Update remote_host accordingly
remote_host=10.10.10.10
remote_host=dentropy.local
echo remote_host
scp -r root@$remote_host:/srv/wireguard .
scp root@$remote_host:~/.config/rclone/rclone.conf .
# A single wireugard config
# Remember you can replace 1 with number 1 through 10
scp -r root@remote_host:/srv/wireguard/config/peer1 .
Using Wireguard on Linux
Instructions to install Wireguard
sudo ls /etc/wireguard
sudo cp peer1.conf /etc/wireguard
wg-quick up peer1
Troubleshooting
docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' umbrel_wireguard
docker logs urbit_manager_1
docker logs urbit_app_proxy_1
docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' urbit_app_proxy_1
docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' urbit_manager_1
docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' nginx
docker exec -it umbrel_wireguard bash
ssh -R 80:localhost:80 root@remote_host
