Hi all -
Power outages last night due to massive thunderstorm. I’ve tried pretty much everything I can short of getting a new SD card.
I’ve tried systemctl <stop / start> umbrel-startup. I’ve tried to stop all the scripts and then configure (I receive an error on this step as well) and restart the scripts. I’ve reflashed the card several times.
The card doesnt seem to be an issue - I can flash the new OS to it but I cannot get the docker services to progress. See below. Something is obviously corrupted - is it the SSD?
Any help you have would be appreciated.
Starting Docker services…
WARNING: The TOR_PROXY_PORT variable is not set. Defaulting to a blank string.
WARNING: The TOR_PROXY_IP variable is not set. Defaulting to a blank string.
WARNING: The NGINX_PORT variable is not set. Defaulting to a blank string.
WARNING: The NGINX_IP variable is not set. Defaulting to a blank string.
WARNING: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
WARNING: The UMBREL_AUTH_SECRET variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
WARNING: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
WARNING: The MANAGER_IP variable is not set. Defaulting to a blank string.
WARNING: The AUTH_PORT variable is not set. Defaulting to a blank string.
WARNING: The AUTH_IP variable is not set. Defaulting to a blank string.
WARNING: The NETWORK_IP variable is not set. Defaulting to a blank string.
Failed to start containers
