Core Lightning app stops working after hours re/installation
first of all sorry my English. I have installed Umbrel OS in an Minisforum PC. Everything seems ok except for the de “Core Lightning app”. This apps only works for a couple hours, then fails.
The only way to recover it is uninstalling and reinstalling it. But I have said, it only works again for a few weeks.
I don’t want to start using it in my first steps in lightning with this failing repetitively
Greetings
temporal solution
thanks to IA problem seems to get solved open a terminal session and sending this comand:
sudo chmod 777 /home/umbrel/umbrel/app-data/core-lightning/data/lightningd/bitcoin
It is been working a few days, but failed again after un app update.
Solved again till next update I suppose
Greetings
