Change Nextcloud data location
Guide: Change Data Storage Location for Nextcloud Docker Installation
This guide will help you change the data storage location for your Nextcloud Docker installation to different disk mounted as /mnt/tank/
Step 1: Stop the Nextcloud Container
  1. Use right click stop in Umbrel WebUI
Step 2: Create new partition and new data directory
  1. Install xfsprogs
sudo apt update
sudo apt install xfsprogs
  1. Format and mount the partition as XFS:
sudo mkfs.xfs /dev/sdb1
sudo mount /dev/sdb1 /mnt/tank
  1. Create the new directory for Nextcloud data:
sudo mkdir -p /mnt/tank/nextcloud
  1. Set the correct permissions:
sudo chown -R www-data:www-data /mnt/tank/nextcloud
Step 3: Identify the Current Data Directory (start, run inspect, and stop again nextcloud)
  1. Inspect the Nextcloud container to find the current data directory:
docker inspect nextcloud_web_1
  1. Look for the Mounts section in the output. It will show the current source (host) and destination (container) paths for the data volume. For example:
"Mounts": [
        "Type": "bind",
        "Source": "/home/umbrel/umbrel/app-data/nextcloud/data/nextcloud",
        "Destination": "/var/www/html",
        "Mode": "rw",
        "RW": true,
        "Propagation": "rprivate"
  • Source is the current data directory on the host (e.g., /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud).
  • Destination is the mount point inside the container (e.g., /var/www/html).
Step 4: Copy Existing Data to the New Location (This might take a while)
  1. Copy the existing Nextcloud data to the new location using rsync:
sudo rsync -av /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud/ /mnt/tank/nextcloud/`
  1. Verify the data has been copied:
ls -la /mnt/tank/nextcloud
Step 5: Update the Docker Configuration
  1. Open the docker-compose.yml file:
sudo nano /home/umbrel/umbrel/app-data/nextcloud/docker-compose.yml
  1. Locate the volumes section for the web service and update it:
volumes:
  - /mnt/tank/nextcloud:/var/www/html
  1. Save and exit the file.
Step 6: Restart the Nextcloud Container
  1. Use right click restart in Umbrel WebUI
Step 7: Verify the Changes
  1. Log in to the Nextcloud web interface.
  2. Verify that all files, folders, and apps are accessible.
  3. Upload a new file and confirm it appears in /mnt/tank/nextcloud/data/umbrel/files.
Step 8: Clean Up the Old Data Directory (Optional)
  1. Delete the old data directory to free up space:
sudo rm -rf /home/umbrel/umbrel/app-data/nextcloud/data/nextcloud
Step 9: Ensure Persistent Mount After Reboot
  1. Find the UUID of /dev/sdb1:
sudo blkid /dev/sdb1
  1. Edit the /etc/fstab file:
sudo nano /etc/fstab
  1. Add the following line to the end of the file:
    UUID=<YOUR DISK UUID> /mnt/tank xfs defaults 0 2
    example: UUID=1190bd87-aa96-4993-8413-1c1da928fc77 /mnt/tank xfs defaults 0 2
  2. Save and exit the file.
Step 10: Final Verification
  1. Reboot the system
  2. After reboot, verify that /dev/sdb1 is mounted to /mnt/tank:
df -h /mnt/tank
  1. Check that Nextcloud is functioning correctly.
Troubleshooting
  • If the container fails to start, check the logs:
    docker logs nextcloud_web_1
  • If the mount fails after reboot, verify the /etc/fstab entry and check for errors in the system logs:
    journalctl -xe
  • If you update you need to do this again
Great tutorial! Thanks for this!
I used this guide but I got 2 errors.
Summary
An exception occured while running the setup check: InvalidArgumentException: URL is missing scheme or host in /var/www/html/lib/public/SetupCheck/CheckServerResponseTrait.php:154 Stack trace: #0 /var/www/html/lib/public/SetupCheck/CheckServerResponseTrait.php(84): OCA\Settings\SetupChecks\WellKnownUrls->normalizeUrl(‘https://fd0b:10…’, true) #1 /var/www/html/lib/public/SetupCheck/CheckServerResponseTrait.php(116): OCA\Settings\SetupChecks\WellKnownUrls->getTestUrls(‘/.well-known/we…’, true) #2 /var/www/html/apps/settings/lib/SetupChecks/WellKnownUrls.php(57): OCA\Settings\SetupChecks\WellKnownUrls->runRequest(‘get’, ‘/.well-known/we…’, Array, true) #3 /var/www/html/lib/private/SetupCheck/SetupCheckManager.php(34): OCA\Settings\SetupChecks\WellKnownUrls->run() #4 /var/www/html/apps/settings/lib/Controller/CheckSetupController.php(132): OC\SetupCheck\SetupCheckManager->runAll() #5 /var/www/html/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\Settings\Controller\CheckSetupController->check() #6 /var/www/html/lib/private/AppFramework/Http/Dispatcher.php(118): OC\AppFramework\Http\Dispatcher->executeController(Object(OCA\Settings\Controller\CheckSetupController), ‘check’) #7 /var/www/html/lib/private/AppFramework/App.php(153): OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Settings\Controller\CheckSetupController), ‘check’) #8 /var/www/html/lib/private/Route/Router.php(321): OC\AppFramework\App::main(‘OCA\\Settings\\Co…’, ‘check’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array) #9 /var/www/html/lib/base.php(1155): OC\Route\Router->match(‘/settings/ajax/…’) #10 /var/www/html/index.php(25): OC::handleRequest() #11 {main}
Summary
echnical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- core
	- INVALID_HASH
		- .htaccess
Raw output
Array
    [core] => Array
            [INVALID_HASH] => Array
                    [.htaccess] => Array
                            [expected] => 418f0babf39f82e537d12028229189633a7941160c27c3410032af498008a65637b8d1ee64abc63a6321c3d1ef8cde31fe58cee00d8b32821480501111977c34
                            [current] => 7bbf9de971f4089569e419283ed84395ec49f2f5557cd5d65c70dd65c65b91075bb8f0a1c83ceb209afa351fed04f6fedf5f135ff35df9f033ef9494a7b2c967
