after reading solution found on here it seems im not using the right syntax in putty as i cant get it to execute the “app” executable can someone point me in the right direction - my lnbits instance is stuck on uninstalling.
im using $~media/btcssd/umbrel/scripts/app uninstall “name of the app” to no avail
