Cannot uninstall or update gitea
Hi there
I have something wrong with my Gitea installation. It just comes up as “Not Running” in the UI. When I try to update it through the UI, it gets stuck at 1%.
When trying to uninstall (have to use the CLI tool because there is no “Uninstall” option on the UI icon), I get the following response (seems to want to try to stop the service, but can’t. I’m sure it’s not even running)
umbrel@umbrel:~$ umbreld client apps.stop.mutate --appId gitea
TRPCClientError: Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop gitea
    at TRPCClientError.from (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/TRPCClientError-38f9a32a.mjs:27:20)
    at file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/links/httpLink.mjs:35:60
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
  meta: {
    response: Response {
      [Symbol(realm)]: null,
      [Symbol(state)]: [Object],
      [Symbol(headers)]: [HeadersList]
    responseJSON: { error: [Object] }
  shape: {
    message: 'Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop gitea',
    code: -32603,
    data: {
      code: 'INTERNAL_SERVER_ERROR',
      httpStatus: 500,
      stack: 'Error: Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop gitea\n' +
        '    at makeError (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/lib/error.js:60:11)\n' +
        '    at handlePromise (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/index.js:124:26)\n' +
        '    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n' +
        '    at async RetryOperation._fn (file:///usr/local/lib/node_modules/umbreld/node_modules/p-retry/index.js:55:13)',
      path: 'apps.stop',
      zodError: null
  data: {
    httpStatus: 500,
    path: 'apps.stop',
    zodError: null
  [cause]: undefined
Any help would be really appreciated. I can provide whatever logs are needed.
I’ve already backed up my repos - so if I need to remove & reinstall then that’s fine.
I’m running UmbrelOS 1.2.2
Thanks in advance
I also have this issue with several apps, e.g umbreld client apps.stop.mutate --appId bluewallet
It’s not possible to uninstall from UI or command line
message: ‘Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop bluewallet’,
code: -32603,
data: {
code: ‘INTERNAL_SERVER_ERROR’,
httpStatus: 500,
I managed to muddle my way into a solution for this. I noticed in the logs there was some mention of a missing “APP_GITEA_SSH_PORT”. I could see that variable (I think that’s the right term) in the docker-compose.yml file, but not defined anywhere. I jumped on to the umbrel-apps Gitea repo and saw that it should’ve been defined in the exports.sh file, but mine was blank.
I insert the export APP_GITEA_SSH_PORT=2222 line in there and restarted the device. When it came back up, Gitea still wasn’t running, but at least I could uninstall it now.
So @mpalladi maybe you could look into your logs too to see whether there’s any kind of missing export/variable stuff there. I think that’s what was stopping it from being “stopped” at all in the first place.
