Thanks
I believe it is not supported in LND now.
WOW…thanks for the QUICK reply…I will wait…
You guys are great!
https://guides.getalby.com/overall-guide/alby-browser-extension/connect-lightning-wallets-and-nodes-to-the-alby-extension/connect-umbrel-to-alby
An workaround if you want.
