i’m running version 1.3.0-patch.1 but noticed that the “Latest Blocks” cards flash momentarily when page loads but doesn’t populate. any way to get this working on my end again?
thanks.
hey, this looks more like a browser rendering issue than missing block data. The Latest Blocks cards use a WebGL animation, and I found a similar report where they showed up normally in another browser.
Could you try opening Bitcoin Node in a different browser and see if they appear there? Also curious, did the cards previously work in the same browser from your screenshot, or has that section always been blank there?
hi Aiden.
you’re right on the money; i tried loading the node in a different browser (Firefox) and all fields populate as intended. my Brave browser doesn’t populate the block cards, but populates everything else (ie the connections globe and all “Insights” elements).
for reference, the block cards did previously display on Brave.
glad to know it’s an issue on the browser’s end and not the node.
