Bitcoin app Not Running
To reset the data you can SSH in and run
sudo rm ~/umbrel/.umbrel && sudo reboot
This will give you a fresh install and you can re-setup Umbrel. However something is wrong, it should only take you 2-3 days to sync Bitcoin.
I noticed you aren’t using the official Raspberry Pi power supply. This is often a cause of filesystem corruption. I would recommend purchasing an official power supply because you may suffer from the same problems again.
OK right, i’ll check for a new power supply then.
Just did the command, it says : rm: cannot remove ‘/home/umbrel/umbrel/.umbrel’: Bad message
Ah this is because of filesystem corruption.
You can use your computer to format the SSD instead. If you Arne’t sure how to od that you can follow these instructions: How to Format an External Hard Drive: Windows 10, 11, Mac
So
Hey mate, thanks I just tried this and it worked in giving me a fresh Umbrel install page. Then when I tried to install the bitcoin app, it won’t install, just says "not running " again !
Damn, what the hell is going on?
@skintone what power supply do you have? Is it the official Raspberry Pi power supply?
Hello,
App is once again stuck at starting… Can you help ?
Here are the logs. Thanks :slight_smile:
umbrel_umbrel_2024-04-03_09-18.log (49.7 KB)
umbrel_bitcoin_2024-04-03_09-18.log (119.3 KB)
I am having the same problem. However, Umbrel shows none of my apps running, and none of them are clickable.
Same problem. After updating to Umbrel OS 1 on Raspberry Pi it’s as if it lost internet connection. Unable to install any apps. It say’s “Installing 0%” for 1 second then says “Not Running”. This happens with all apps as well as when I “UmbrelOS Check for Update”. I chucked my Raspberry Pi and purchased a new Umbrel Home and, unfortunately am experiencing the exact same problem.
I was having the same issue after I updated from 0.5.4 to the new OS.
I tried everything that you have mentioned above and ended up just restarting from scratch with this reboot command in the terminal (I like the terminal directly within the OS). It reset everything and is now downloading the blockchain from the Genesis.
I think everything is working fine now but will keep an eye on things. Thanks for your help, Luke.
Try this, but this method will delete all app data. Be careful.
Possible solution:
