Hi guys, I need a help with my UmbrelOs.
Recently, I added two 1 TB SATA hard drives to my computer running UmbrelOS.I was able to detect the drives and mount them manually, but they do not appear in the Files app. I also tried to configure them to mount automatically by editing the /etc/fstab file. However, every time I reboot the system, the file is restored to its default configuration, and all of my changes are lost.
I would like to know:
How can I make the hard drives appear in the Files app?
How can I configure them to mount automatically on every boot, even after restarting UmbrelOS?
Below are the commands I used, along with a screenshot to help illustrate the issue.
umbrel@umbrel:~/umbrel/home$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 111.8G 0 disk
├─sda1 8:1 0 200M 0 part /run/rugix/mounts/config
├─sda2 8:2 0 9.6G 0 part /run/rugix/mounts/system
├─sda3 8:3 0 9.6G 0 part
└─sda4 8:4 0 92.3G 0 part /mnt/root/var/lib/systemd/timesync
/mnt/root/var/log
/var/log
/mnt/root/var/lib/docker
/var/lib/docker
/kopia
/home
/data
/run/rugix/state
/run/rugix/mounts/data
sdb 8:16 0 931.5G 0 disk
└─sdb1 8:17 0 931.5G 0 part /data/umbrel-os/home
/home
sdc 8:32 0 931.5G 0 disk
├─sdc1 8:33 0 931G 0 part
└─sdc2 8:34 0 519M 0 part
umbrel@umbrel:~$ /mnt/“Disco 1 - Backup”
-bash: /mnt/Disco 1 - Backup: Is a directory
umbrel@umbrel:~$ cd “/mnt/Disco 1 - Backup”
umbrel@umbrel:/mnt/Disco 1 - Backup$ ls
‘$RECYCLE.BIN’ ‘Arquivos Antigos’ Backup Softwares Trabalho
Administrativo ‘BACKUP HD RECUPERADO’ Estudos ‘System Volume Information’ media
umbrel@umbrel:/mnt$ ls /mnt
‘Disco 1 - Backup’ HD02 HD_02 root
umbrel@umbrel:/mnt$ ls -la /mnt
total 24
drwxr-xr-x 1 root root 4096 Jul 23 22:19 .
drwxr-xr-x 1 root root 4096 Jul 23 19:57 ..
drwxrwxrwx 1 root root 4096 May 22 09:47 ‘Disco 1 - Backup’
drwxr-xr-x 4 root root 4096 Jul 23 19:53 HD02
drwxr-xr-x 2 root root 4096 Jul 23 21:48 HD_02
drwxr-xr-x 1 root root 4096 Jul 23 19:57 root
umbrel@umbrel:~$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
└─sda1 ext4 1.0 HD02 c0ad99d1-340e-4d00-b989-d92335df7383 869.2G 0% /mnt/root/mnt/HD02
/mnt/HD02
sdc
├─sdc1 ntfs Disco 1 - Backup 02CA0359CA0347FD 720.8G 23% /mnt/root/mnt/Disco 1 - Backup
│ /mnt/Disco 1 - Backup
└─sdc2 ntfs EEC8B8A8C8B87087
zram0 swap 1 zram0 643eabe8-b0fa-4d0a-8547-ec64981597c3 [SWAP]
