The node has been running for only a week but I’m thinking of shutting-down/rebooting… just waiting to stack a few tasks together so I do it once hoping will be the last one
ATM, the workflow look’s something like the below:
For just 1h off, I would not bother too much, is a short time and some peers not even notice it.
Just pay attention, if you can do it when you do not have HTLCs in fly. That could be problematic for peers and for you if something bad happen.
Is not really necessary, but is recommended.
A copy of the mSD is good to have.
A copy of SSD is hard to achieve, you need to shut down your node and takes time and you will always have another state of your node. That is not good.
If you really want to have a secured copy of your data, use a RAID system, (but not software!), with 2 or 3 disks. That is not achievable with a RPi…
Hello @DarthCoin - it is now 3+ years since your reply. Is it still not possible (or advisable) to save a copy of my node from one SDD to another SSD?
The reason I want to do so is that it took 30+ days to download and sync the entire node in the first place. So if there’s any issue with the primary SSD, I can run my node from the back-up SSD. Ideally, without a long period of downtime. However, your point about having another state of the backup node is well taken.
FYI - I am asking you, as you seem to provide the most useful replies in this community. I don’t create new posts and have read through many existing posts to find solutions. Appreciate your expertise.
