Unofficial Guide: How to add more storage
Thanks for the instruction, love it.
hello help please
when i enter sudo mount command i got
/home/umbrel/umbrel/home/local-disk: mount(2) system call failed: Not a directory
What I did wrong?
And I also have empty directory
/home/umbrel/umbrel/external/
Well, as the error message says, it’s like you entered a path which is not a directory (does not exist or is a file?). Please paste the full command you entered and the full response.
And check the previous steps (e.g. sudo lsblk ):
# Check your drive name (look for sdb, sdc, etc. - it will be the size of your new drive)
# My drive is named 'Untitled' ¯\_(ツ)_/¯
sudo lsblk
Hi there! I think I seriously screwed something up…
I followed the steps exactly as outlined in djtony707’s guide (I’m attempting to add my external HDD as extra storage to my Plex server), and after a second restart from the web GUI, now all of a sudden my Umbrel is hung in emergency mode, saying the root user is locked out.
It restarted fine at first, after following djtony707’s steps, the Storage folder with all the app redirects seemed to show up as expected. However, I didn’t see the total storage updated in UmbrelOS (just the on-board storage as before I connected the external HDD), and wanted to start tinkering with that to see why. I restarted again from the UmbrelOS Settings UI, and the restart dialog just hung on the “Restarting, don’t close or refresh” page. I didn’t close that page or refresh it or anything (in fact, it’s still open).
When I went to check the system itself on its monitor, I saw that drive mounting had failed:
[FAILED] Failed to mount home-umbrel-umbrel-home-Storage.mount - home/umbrel/umbrel/Storage.
There’s more to that one, but that’s the gist of it– it directs to systemctl status. Under that is:
[DEPEND] Dependency failed for local.fs-target - Local File Systems
Looks like everything else reports OK. Unfortunately, now it’s stuck in “Emergency Mode” and says that it cannot open console because root user is locked. What do I do? Pressing “Enter to continue” as it says simply loops me back around to the same “You are in emergency mode” dialog.
If you have a moment today, I’d really appreciate any input on how to fix this.Thanks in advance!
This fstab entry style worked for me too, without the pain of figuring out how to add a PARTUUID without risking data loss.
Considering the number of community members who want to use multiple drives with Umbrel, it seems to me like it should be a HIGH PRIORITY to get this included into the web UI.
