Unable to Unlock Wallet
ligntning_app_1 → Does anyone know if this infinite loop in the log is normal? I am also unable pay iinvoice due to this error: Must unlock wallet.
Apparently this problem was introduced after upgrade 2 weeks ago to version 1.3.1.
Checking LND status…
LND already unlocked!
[backup-monitor] Checking channel backup…
[backup-monitor] Sleeping…
Have the same issue.
Sending payments works with Alby wallet.
It started after the update that rolled out about two weeks ago. Is anyone besides me and EI‑Z dealing with this?
unlock wallet issue i’ve usually found, historically is something else going wrong in an individual setup with a random manual line change in a config file or a dependency error like back in the days when there used to be peers.dat errors, someone post their full debug log here in a text file however u want, maybe i or someone else can spot something @umbrelio share the full debug log too we can see if another app is failing i.e. bitcoin which LND relies on… or let us know how it’s going here or on the discord Support | Umbrel cheers. AI might be able to pick up ur debug log too you can print yourself, or share here, as a note it doesn’t include any PII only what apps you have installed.
Same problem here since latest update. Discovered only just today because payments via connected apps are fine. My NWC connection works fine in other apps. It’s just payment of an invoice in the LND app itself that fails. I changed some settings via the app, but never in any config files. Here are some logs:
lightning_app_log_sanitized .txt (5.7 KB)
lnd_log_sanitized .txt (23.2 KB)
Must unlock wallet
/v1/lnd/lightning/payInvoice
LndError: Unable to send lightning payment
    at /app/apps/backend/services/lnd.js:109:18
"POST /v1/lnd/lightning/payInvoice HTTP/1.1" 403 20
I have exactly the same issue described in the logs above.
Hey Rainman… Have you found a way to solve this?
No I have not. I used a different payment method instead so the need is gone. But external connected apps should work so maybe you can give that a try. Meanwhile waiting for a fix.
I have exactly the same issue being unable to pay a lightning invoice from Lightning Node with message “Must unlock wallet”. What does this mean and what’s the solution?
I think @mayank is from Umbrel team. Let’s see if this mention will help.
Hi everyone, sorry about this!
We’ve released a Lightning Node update that fixes the “Must unlock wallet” error when sending payments directly from the Lightning Node app.
So please update the Lightning Node from the Umbrel App Store, then try your payment again.
Also, the repeated “Checking LND status / LND already unlocked” messages are normal status checks, so there’s no need to worry about those.
If you still run into the error after updating, feel free to drop your logs here and we’ll take another look.
