# TOR Not Working
**URL:** <https://community.umbrel.com/t/tor-not-working/12371>\
**Created:** [May 9, 2023, 6:51pm UTC](https://community.umbrel.com/t/tor-not-working/12371 "2023-05-09T18:51:21Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![miyagi](https://avatars.discourse-cdn.com/v4/letter/m/9e8a1a/32.png) [@miyagi](https://community.umbrel.com/u/miyagi)\
**Post date:** [May 9, 2023, 6:51pm UTC](https://community.umbrel.com/t/tor-not-working/12371/1 "2023-05-09T18:51:21Z")
</div>
My Umbrel Node will no-longer connect via Tor. My log shows the following:
-9418 connections died in state connecting with SSL state (No SSL object)
-Problem bootstrapping. Stuck at 51% (Loading\_descriptors): Loading relay descriptors. (Connection timed out; TIMEOUT; count 4563; recommendation warn; …
-9419 connections failed…
-9420 connections failed…
-9421 connections failed…
Can anyone interpret what’s going on with my Node. When fees go down, I want to open some lightning channels but with Tor not working, I’m worried I’ll have some problems.
Thanks,
