Storage Manager (2.0) doesn't list SATA drives behind an HBA (TRAN=sas) - filter by transport type?
Hi all,
I’m running umbrelOS 2.0 on a normal PC (not Umbrel Pro) and Storage Manager doesn’t show any drives connected through an HBA, although the same drives show up when they are on the motherboard SATA ports.
My setup:
  • Motherboard: Intel B85
  • Boot/system disk: Corsair Force GT SSD on the motherboard SATA port
  • Data drives: 8x 2.5" 1 TB SATA laptop drives (4x WD10JP*, 4x HGST HTS541010A9E680)
What I tried:
  1. Adaptec ASR-71605 in HBA mode: all 8 drives are visible over SSH (/dev/sdX, correct serials, wwn and ata by-id links), but they are NOT shown in Storage Manager. lsblk showed an empty TRAN and RM=1 (removable) for every one of them.
  2. Same drives on the motherboard SATA ports: they ARE shown in Storage Manager (TRAN=sata). With 6 drives I was only offered a stripe or a 1-drive-failsafe option.
  3. Replaced the Adaptec with an LSI 9300-16i (IT/HBA mode, mpt3sas driver): RM is now 0 and everything else looks like a normal SATA disk (ID_BUS=ata, ID_ATA_SATA=1, ROTA=1), but the drives are still NOT shown in Storage Manager.
  4. With the 9300 still connected, I added one extra WD drive on a motherboard SATA port: that drive IS shown in Storage Manager, the 8 drives on the 9300 are not.
lsblk -o NAME,SIZE,TRAN,MODEL,SERIAL,ROTA,RM (drives on the 9300 plus one on the motherboard port):
NAME SIZE TRAN MODEL SERIAL ROTA RM
sda 931.5G sas WDC WD10JPVX-22JC3T0 WD-WX11AA5L26CC 1 0
sdb 931.5G sas WDC WD10JPVX-22JC3T0 WD-WX91EA4E9P4F 1 0
sdc 931.5G sas WDC WD10JPVX-60JC3T0 WD-WX21EC3ACD27 1 0
sdd 223.6G sata Corsair Force GT 12038201000009890468 0 0
sde 931.5G sas WDC WD10JPCX-24UE4T0 WD-WX81A75DJP3S 1 0
sdf 931.5G sas HGST HTS541010A9E680 JD1009DM2UEDDK 1 0
sdg 931.5G sas HGST HTS541010A9E680 JD1009DM34U08K 1 0
sdh 931.5G sas HGST HTS541010A9E680 JD1009CCKK13LK 1 0
sdi 931.5G sas HGST HTS541010A9E680 JA108NSB15NN1R 1 0
sdj 931.5G sata WDC WD10JPCX-24UE4T0 WD-WXP1AC5PC8KU 1 0
udevadm for a drive on the 9300: ID_BUS=ata, ID_ATA_SATA=1, ID_PATH=pci-0000:05:00.0-sas-phy3-lun-0
udevadm for sdj (motherboard): ID_BUS=ata, ID_ATA_SATA=1, ID_PATH=pci-0000:00:1f.2-ata-3.0
The only difference I can see is TRAN (sas vs sata) and the ID_PATH. SMART is fine on the drives, and I could build a ZFS raidz1 pool on them manually over SSH, so the hardware works.
My question: does Storage Manager only accept drives whose transport is sata/nvme, so that SATA drives behind a SAS HBA (TRAN=sas) are ignored?
If so, is support for HBA-attached drives planned, or is there a setting or workaround to get them listed?
Also, is a layout with more than one drive of redundancy (e.g. RAIDZ2) planned for non-Pro hardware?
Happy to run any commands or send logs that would help.
Thanks!
hey, the Umbrel team confirmed SAS support is coming in umbrelOS 2.1 this month, so it’s probably worth holding off until then rather than swapping any more hardware or trying to work around the filter. Hopefully that’ll get your HBA-connected drives showing up properly.
Thnxx,
I saw that the new version was coming, but did not know that they would extend SAS support.
Thanks for the info!
