Porém, inicia com cartão SD no Slot ou numa entrada USB através de adaptador. Mensagem na sequência recomenda usar o SSD, porém não funciona, mas na opção SD avisa que haveria lentidão e risco de dano, mas que os Apps seriam instalados nesse SD, ficando o SSD para arquivos externos. Um Node de Bitcoin, por exemplo, seria assim? Os arquivos de atualização ficariam no SSD externo?
Hey José! Before anything else, the 16.8TB jumps out at me. As far as I know there’s no real portable SSD that big (the largest genuine ones are around 8TB), and odd sizes like 16TB or 16.8TB are a classic sign of a fake drive. Those report a huge size but only have maybe 64GB to 512GB inside, and anything written past the real size gets lost or overwrites older data. That would explain both things you’re seeing: umbrelOS won’t boot from it, and setting it up as storage from the SD card fails too.
Easy way to check: run H2testw (Windows) or f3 (Mac/Linux) on the drive. It fills the whole drive with test data and reads it back, so you’ll see the real capacity. Copy anything important off it first just in case. If it turns out to be fake, I’d return it and grab an SSD from a known brand like Samsung, Crucial or WD. For a Bitcoin node, 2TB gives you plenty of room for years.
If the drive checks out fine, two other things are worth ruling out on the Pi 5:
1. Power. Use the official Raspberry Pi 27W USB-C power supply. With a weaker one, the Pi limits power to the USB ports and the SSD can fail to start or drop out.
2. If you flashed it from Windows, Windows can quietly change the drive’s partition table and then the Pi can’t find anything to boot. Flashing from a Mac or Linux machine avoids it, and there’s a test image with a fix for it here: https://download.umbrel.com/public-windows-flash-fix/umbrelos-pi.img.zip
On your other questions: if you keep running from the SD card, apps and their data live on the SD by default, so yes, a Bitcoin node would sync onto the SD. I really wouldn’t do that. The blockchain is way too big for most cards, it’d be slow, and all those writes wear SD cards out fast. You can move a single app to the external SSD from its settings (Storage, then App storage, then Move, with the drive formatted as ext4), but those apps aren’t included in umbrelOS backups. As far as I know, umbrelOS updates always go to the drive it’s running from (the SD card in that case), not the external SSD.
