RTL begins to install, then stops
When attempting to install RTL, the OS initially behaves as though it is installing, reaching a couple percent in progress, then stops with no explanation. I have Lightning Node installed.
What’s the hardware? You don’t have to be logged in for the installation to continue. Do you have Bitcoin Core or Knots installed?
