# Raspberry Pi Kaput
**URL:** <https://community.umbrel.com/t/raspberry-pi-kaput/11864>\
**Created:** [March 19, 2023, 1:31am UTC](https://community.umbrel.com/t/raspberry-pi-kaput/11864 "2023-03-19T01:31:36Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![DougTee](https://avatars.discourse-cdn.com/v4/letter/d/c4cdca/32.png) [@DougTee](https://community.umbrel.com/u/DougTee)\
**Post date:** [March 19, 2023, 1:31am UTC](https://community.umbrel.com/t/raspberry-pi-kaput/11864/1 "2023-03-19T01:31:36Z")
</div>
So I’ve had problems with my Umbrel on the Pi and had it working for awhile. I moved it to a different room and now it wont connect to Ethernet. Cannot find DNS and I get no green light on the PI. I’ve tried rebooting OS to no avail. How can I recover my wallet without buying another Pi? Can I run umbrel on my macbook parallels VM and connect the external drive to reset up the Umbrel is there a way to do this without using the Umbrel software. In the meantime, trying to install Umbrel on MacOS to run through VM debian OS and get this message:
ls: unrecognized option `–almost-all’
usage: ls [-@ABCFGHILOPRSTUWabcdefghiklmnopqrstuvwxy1%,] [–color=when] [-D format] [file …]
sudo: apt-get: command not found
Thanks.
