Pulling neutrino-switcher fails on startup script
Hello,
My node has been offline for 6 days, and I went to the command line to try and fix things but I think I made it worse.
My first step was to run:
And then after:
sudo ~/umbrel/scripts/stop && sleep 10 && sudo ~/umbrel/scripts/start
When I got to the start script, this is the error I got:
Pulling neutrino-switcher (getumbrel/neutrino-switcher:v1.3.0@sha256:399ccea7f39129ff16c9c408f9e68a01dd4671f428273f3c3f401a8a0d2f7ddc)... ERROR: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 192.168.0.1:53: read udp 169.254.10.240:47893->192.168.0.1:53: i/o timeout
I think this docker image was pruned in my earlier command, and I don’t know how to pull this docker image over Tor. I’m connected to the Umbrel via Ethernet
Any help would be appreciated!
