OnlyOffice with Nextcloud issue
Hi, I’m trying to get OnlyOffice working with NextCloud. I follow the instructions and fill in the fields as indicated in OnlyOffice, but when I save it returns “error while trying to connect (Invalid integrity check status)”. Any ideas? Thanks
hey, that sounds like Nextcloud isn’t getting the response it expects from ONLYOFFICE’s health check, rather than an issue with your documents.
Could you try opening the ONLYOFFICE server address you entered with /healthcheck added at the end? It should show just true. If it shows a login/setup page or an error instead, that would help narrow it down. Even if it works in your browser, Nextcloud still needs to be able to reach it directly.
Also, could you share a screenshot of the ONLYOFFICE settings in Nextcloud, including the expanded “Advanced server settings”, with the secret key hidden? And is ONLYOFFICE running on the same Umbrel or somewhere else? Those internal address fields can make a difference here.
Thank for the replay
Healthcheck replays true.
Here are some screenshots:
There is no secret pass in the OnlyOffice Umbrel app
ah, your settings look right, and the blank secret key is normal for the Umbrel app.
I managed to reproduce this: ONLYOFFICE was running fine, but Nextcloud was blocking the connection to its local address. This fixed it on my test install. Open Terminal in Umbrel’s settings, choose umbrelOS, and run:
sudo docker exec -u www-data nextcloud_web_1 php occ config:system:set onlyoffice allow_local_address --type=boolean --value=true
Then click Save again in Nextcloud’s ONLYOFFICE settings. No need to change the addresses or restart anything. Let me know if you still get the error.
Hey, I had to type in the terminal (no copy and paste).
The command returns:
“System config value onlyoffice ==> allow_local_address set to boolean true”.
It works!!!
Thank you very very much
