Multiple pool storage possibility?
First of all, I’d like to apologize if my English isn’t perfect.
I’m a new user, and I’m really enjoying UmbrelOS ! However, I haven’t been able to create an additional storage pool. That made me wonder: is it currently possible to have multiple different storage pools? And if not, that will be supported in the future?
Ideally, I would like to organize my storage like this:
Pool 1 (1× 500 GB SSD): OS, system files, and apps
Pool 2 (1× 2 TB SSD): Personal data and multimedia files
Pool 3 (2× 4 TB HDDs): OneDrive backups and external drive backups
But i don’tknow if this is possible with the actual UmbrelOS storage capacity…
Thanks in advance for your help ! :slight_smile:
hey, umbrelOS currently keeps things simple with one storage pool that you can expand whenever you need more space, rather than managing separate pools
for your setup, I’d use the 500 GB SSD for the OS (even a smaller 128 GB SSD would do). Connect the HDDs and your 2 TB SSD before booting up, then create the HDD storage pool during onboarding and enable SSD acceleration using the 2 TB SSD.
according to the Umbrel devs, SSD acceleration can make HDD pools up to 30x faster, giving you almost SSD-like performance depending on the workload. umbrelOS automatically puts things like app data on the SSD, so you don’t have to figure out what belongs on which drive.
you can still organize your personal files, media and backups into separate folders within that pool.
