goPool - Solo BTC Mining Pool written in goLang
goPool Docker Container for Umbrel updated to v0.1.9 code:
https://github.com/rodb2008/RodB-Umbrel-Community-App-Store.git
Includes an Umbrel Widget too:
NOTE: It was just pointed out that this has been built to work on x86-64 hardware only and that I need to make some changes to add Multi-platform support so that this will work on ARM64 as well.
I have updated the goPool App and goPool Web Widget with Multiplatform Support - x86-64 and ARM64.
goPool β€” version: 0.1.9-RodB1 β€” build: 2026-02-08T20:20PST
It should now work on ARM64 Architecture but I don’t have a device to test it on.
Has been posted to my Umbrel App Store.
Umbrel App Store has been updated to:
goPool β€” version: 0.2.0-RodB1 β€” build: 2026-02-11T12:20PST
(auto adjust share spam grace with vardiff window: x86-64 and ARM64)
Posted an update to goPool on my Community App Store:
goPool - version: 0.2.3-RodB0 - build: 2026-02-16T12:50PST
There are a lot of configuration files changes that you will need to look at in …
~/umbrel/app-data/rodb-gopool/data/config
Review the data in the Examples and update the files on your side, as needed.
