Get new 'Node URI' after 'Lightning Node' reinstallation
Hello community,
I hope you can help. After my ‘Umbrel Home’ stopped booting up after a restart, I had to reset it to factory settings and set it up again with all applications. Since this took several days, the existing Lightning channel was also closed. I did not set up a new node when I set it up again, but restored the existing original node using a seed. The ‘Node pubkey’ remained the same, but a new ’ Node URI’ was assigned to the node. Now the problem is that 1ML and AMBOSS know only the old ‘Node URI’, and the status is no longer updated. How can I announce the new ‘T Node URI’? Or is the node now dead and I have to create a completely new node, which then serves as a new entry point for the creation of channels? What are your experiences and how have you solved such problems?
Many thanks in advance
