when I tried to run
sudo docker compose logs -f bitcoin
when I use the bitcoin id instead, I get this
WARN[0000] The “PWD” variable is not set. Defaulting to a blank string.
Please help if you can
Thanks
when I tried to run
Thanks
figured out a solution, find the container ID
docker ps -a
sudo docker logs --follow container ID
Hope that helps anyone with the same question
