I still use Bitcoin Node Core 28.1.0 on Umbrel OS 0.5.4 (don´t want to update my old raspi since it works nicely ever since).
However I updated Electrs today (0.11.0) an ran into the same issue.
The problem is caused by a broken environment variable in the Electrs app configuration: the P2P address uses an unresolved variable like ${APP_BITCOIN_P2P_…}, which results in an invalid address and makes the electrs_electrs_1 container crash in a loop. Fixing the docker-compose.yml for Electrs and restarting Umbrel solves it.
1. SSH into the Umbrel node
Open a terminal on your computer.
Connect via SSH (replace the IP with your Umbrel node’s IP if needed):
ssh umbrel@umbrel.localor
ssh umbrel@<UMBREL-IP> -
Enter the password for the
umbreluser when prompted.
If you see a warning that the host key has changed, remove the old entry from your local known_hosts file and try again.
2. Go to the Electrs app directory
After logging in, change to the Umbrel base directory:
cd ~/umbrel -
Go into the Electrs app data directory:
cd app-data/electrs
You should now be in /home/umbrel/umbrel/app-data/electrs.
3. Open the Electrs docker-compose file
Open the
docker-compose.ymlfile with a text editor (e.g. nano):nano docker-compose.yml -
Inside this file, find the
electrs:service section. It will look similar to this:electrs: image: getumbrel/electrs:v0.11.0@sha256:... restart: always environment: ELECTRS_LOG_FILTERS: "INFO" ELECTRS_NETWORK: "${APP_BITCOIN_NETWORK_ELECTRS}" ELECTRS_DAEMON_RPC_ADDR: "${APP_BITCOIN_NODE_IP}:${APP_BITCOIN_RPC_PORT}" ELECTRS_DAEMON_P2P_ADDR: "${APP_BITCOIN_NODE_IP}:${APP_BITCOIN_P2P_WHITEB...}" ELECTRS_ELECTRUM_RPC_ADDR: "0.0.0.0:${APP_ELECTRS_NODE_PORT}" ELECTRS_SERVER_BANNER: "Umbrel Electrs (${APP_VERSION})" ELECTRS_DB_DIR: "/data/db" volumes: - "${APP_BITCOIN_DATA_DIR}:/data/.bitcoin:ro" - "${APP_DATA_DIR}/data/electrs:/data" ports: - "${APP_ELECTRS_NODE_PORT}:${APP_ELECTRS_NODE_PORT}" networks: default: ipv4_address: $APP_ELECTRS_NODE_IP
The important line is ELECTRS_DAEMON_P2P_ADDR.
4. Fix the broken P2P address
In the
environment:block, replace the lineELECTRS_DAEMON_P2P_ADDR: "${APP_BITCOIN_NODE_IP}:${APP_BITCOIN_P2P_WHITEB...}"(or any variant using
${APP_BITCOIN_P2P...}) with a static, working value pointing to the Bitcoin container, for example:ELECTRS_DAEMON_P2P_ADDR: "bitcoin_bitcoind_1:8333" -
Make sure you do not change the indentation or other lines.
This forces Electrs to connect to the internal bitcoin_bitcoind_1 service on the standard P2P port 8333 instead of using the broken Umbrel variable.
5. Save the file and exit
In nano:
- Press
Ctrl + Oto write the changes. - Press
Enterto confirm the filename. - Press
Ctrl + Xto exit the editor.
6. Stop and start Umbrel services
Go back to the Umbrel base directory (if you are not already there):
cd ~/umbrel -
Stop all Umbrel services:
sudo ./scripts/stopEnter the
umbrelpassword when prompted. -
Start all Umbrel services again:
sudo ./scripts/start
Wait a few minutes for all containers to come up.
7. Verify Electrs is running and syncing
Check the running containers:
docker psYou should see
electrs_electrs_1with statusUp(notRestarting). -
In the Umbrel web UI, open the Electrs app. The previous “Connecting to Electrs server…” message should be replaced by a real sync progress value (percentage).
If you look at the Electrs logs, you should see it indexing blocks (messages like “indexing 2000 blocks” and increasing heights), which indicates the index is being built.
