Electrs local network link default name incorrect
UmbrelOS 1.1.2 installed & running well. Bitcoin node installed. However after the installation of Electrs and its opening the Local network address became “umbrel.local.local”.
I tried to find the config file to change it to is “umbrel.local” with nano using terminal but unsuccessful.
The actual local address of the umbrel node in the LAN is “umbrel.local”.
Who knows how to correct the address or if it is really necessary?
Please advise!
